Chronicles of the Dirranbandi & Toowoomba Light Railway
Re: Chronicles of the Dirranbandi & Toowoomba Light Railway
Like you, I first turn the wheel profile parallel with the topslide clamped, which minimises chatter when turning the root radius. I then turn the taper using the topslide, as there's no chatter if the tool is sharp and isn't trying to form a radius.
The Colchester Triumph 2000 I had in the mech lab would have easily turned steel wheels this size in one operation by plunge cutting with a form tool. The mini lathe would be hard pressed to do that in graphite filled nylon......
I sometimes wonder how many mini-lathes are sitting around rusting, due to quality issues that the average aspiring ME can't overcome.
What brand and model lathe have you decided to buy?
Having spent 40 yrs working in a QC lab and running it for about half that, I don't pin much faith in an ISO 9001 certificate on the boardroom wall. My view is much the same as whoever wrote the last para of the Wikipedia entry on ISO 9001.
All it really demonstrates is that the company has a documentation system for how they produce their particular brand of crap. British Leyland would have had no problem getting certification, but they still wouldn't have produced a decent car, let alone a Rolls-Royce........
- -steves-
I could be wrong but I think the Warco WM180 is actually made by weiss (a chinese company) as are a lot of lathes that are just rebadged. I think the one you have is actually this one http://www.weiss.com.cn/products_detail ... d=210.html and they are incredible lathes. I have the 250 version and I love it, but mine is from Amadeal although he openly admits where they come from and they just badge them up for him and paint them in his preference of colours, which happens to be blue and white as it's their standard colour. They even give you the spare remaining blue and white paint for any touch ups that are required.
- -steves-
If you had been stuck for help lifting it I could have popped up one day and lent a hand, would have given me the chance to learn lots of things from you as well
- -steves-
I may well take you up on that offer at some point Cannock is where I sometimes go mountain biking, so it's not the other end of the planet
The spec looks good, much the same as Optimum without the price premium for the extra 10mm of centre height. Interesting that Warco test and measure each machine before delivery.
The only Weiss distributor in Oz doesn't bring in the smaller size lathes, so the choices here are basically Optimum and Seig.
- Palmerston
Well everyone can order a container full of whatever machinery or products from China with badges and colours of your choice. We could even label them as "Garden Railway Forum" This is the so called "private label".Oily Rag wrote: ↑Wed Jul 17, 2019 5:47 pm You are correct Steve. The Warco model is manufactured by WEISS. They make all the OPTIMUM badged lathes which are allegedly doctored in Germany before sale and it is claimed they have German engineering supervision on site. Plus there is a WEISS in the Netherlands doing the same items. Its all a bit of a tangled web really. In actual fact there are few manufacturers as such much of it badging.
Some Optimum machines are manufactured by a joint venture from Optimum in Yangzhou. You can also order them with your private label. Some of Chester Hobby lathes look a like.
Generally the chinese gouvernment for whatever product produces a "design" for free and appoints several factories. The money and lessons learnt from those first batches will then be used to improve things or fit useless improvements due to lack of experience with use of the product.
Live steam on 45 & 184mm, battery 45mm only.
- Palmerston
I replaced my Weiss 210 lathe three months ago with an Optimum 2807V.
Its taken me a lot of effort to sort the problems with this lathe. WHY? Optimum sells through dealerships which get their machines from a local or regional importer which gets them from Germany or possibly direct from China. I cant imagen my machine has been tested in the German warehouse.
With the Weiss lathe the few problems were quickly sorted by the seller which has a private label business in tools, like Chester, Axminster, Warco, Amadeal etc. They often just take parts of the machines they have in stock intended for parts. As there is no middleman quick service for the customer and still earn enough profit .
The dealership i bought the machine from just blames the importer which took 6 weeks to respond…..which blames the German warehouse which had the wrong parts in stock... 12 weeks on...
Optimum has improved their milling machines with a quick release toolholder without the need for difficult extra parts (money) though.
you obviously know a lot about machine tools. It must be much more of a problem for thse of us who who lack the knowledge and experience.
I have an old EW lathe which was given to me but lacks the shaft which went between the motor and the lathe proper, with belt drives to both. The motor to interim shaft was about 5:1.
I cannot decide whether I should try to make up something or just buy a new lathe.
Don
Don
The EW lathe is listed on Tony Griffiths' website. http://www.lathes.co.uk/ew/index.htmlDonW wrote: ↑Sat Jul 27, 2019 12:19 am I have an old EW lathe which was given to me but lacks the shaft which went between the motor and the lathe proper, with belt drives to both. The motor to interim shaft was about 5:1.
The photos show the as supplied countershaft. There was also a backgeared countershaft that was an extra cost option, along with screwcutting, etc.
You need to ask yourself a couple of questions. What do you want to make that requires metal working machinery and also if your hobby is making models, or restoring old machinery.
Making parts for a restoration will likely require access to a lathe and maybe other machinery, as parts for a 60 year old lathe will be as rare as hens teeth.
What you wish to make will determine if a restored EW will do the job and what other machinery you will need.
For the record Graeme, we all enjoy on here you being a perfectionist given the work you produce
Solid leadscrew nuts were a standard fitting on a lot of small lathes and Cowells still use one. The EW looks well built for a small lathe of that era, I'd prefer it to an Adept for instance........
The only metal working machinery I had for most of my modelling career before retirement was a late model Unimat SL that I bought new (predictably the Unimat 3 came out a year later). That taught me more than I needed to know about taking numerous light cuts on a machine with what amounted to a full leadscrew nut. It did everything I needed in HO, but I'd still be turning my first set of wheels in garden scale if I hadn't bought the Sieg C2 when I retired.
How rigid do you find the topslide on the new Warco, compared to your old Clarke?
Thank you for you advice Gents. This is something I will have to resolve but to be honest finishing other tasks around the house and garden so I can then get on with building a railway comes first.
Reading your latest post tells me how ignorant I am about machine tools. I think it is difficult to say exactly what I would use a lathe to do as I am convinced there must be lots of things it would make easier if I did but know it. Some years ago working as a development engineer I did have access to such equipment and have aquired a Proxxon MF70 Mill. Which I need to learn to use.
Don
Don
