Thanks Phillip for your info. A Willow bush Phillip, can't say I have ever seen one. Would be easier to look after would it. Only reason I am asking is, the back does look rather open now and has the back fences don't belong to the landlord, I can't see them getting replaced anytime soon.
FINAL NEW FWLR LINE
Re: NEW FWLR LINE
Re: NEW FWLR LINE
I was trying to illustrate what I meant when I said "bush", the technical term is "Pollard".
This shows what can happen:
Re: NEW FWLR LINE
A beautiful looking tree there but potentially back to square one in Rod's case. That probably represents just a couple of years growth too!
Re: NEW FWLR LINE
Depending on your point of view pollarding can be quite appealing where there is plenty of space but in a small garden a bit of a nightmare. I had a very similar situation to Rod about 15 years ago in my garden where the willow was reduced to around 10' tall, the resulting growth the following year was so dense it severly reduced the amount of light getting into the garden. I ended up having to pollard it every year, not my idea of fun so after a few years of doing that I eventually had the tree professionally removed which is what I should have done in the first place.
Re: NEW FWLR LINE
I would have had it completely down also Phil, but the landlord wanted to leave some of it.
May get that guy to come and see if he wants some more big trunks for his sculpting...
Re: NEW FWLR LINE
Well it's been one of those months, not been in the best of health, but got through it. So today Anne and I went into the garden and did a bit of clearing of a bush so we (Anne) could see the little stone wall that was hidden by it. After clearing the debris away it has left a nice bit of space for the extension Anne said we could have....
After some discussion, Anne wanted the line to go to the little patio and stop, so the station could be sited there. I said " I we did it that way, it would mean the loco or anything pulling stock would end up running backwards, has well as forward on one line!" So I have come up with an alternative, though it takes up more room. Something Anne really doesn't want. I think it would be the only way to get any train to run has if it's pulling and not pushing.
I know it did happen, but I don't seem to recall any videos or film of them pushing. Can you tell me if it did, also was it a common practice.
The station could be sited at the top of the line, if it meant keeping the line as low as possible, so Anne had easy access to her Fairy Garden on the right...
It's only a proposal at the moment. I also don't want to be taking too much off the garden. The thinking being, because it's not our own garden, we could't go putting loads of stuff into it, like soil or anything that would drastically change the appearance of the garden. If we had to leave again, we would have to put it back has it was. Can you imagine the work it would take....Plus all the hard work of getting to look something like we would really want it to......
Re: NEW FWLR LINE
It wasn't Rik, but you have given me an inspired idea for my next loco build.
I meant some locos went backwards, but they were nearly always at the front of the train pulling. I don't think they ever pushed from the back did they?
Re: NEW FWLR LINE
Rod,
I think you mean push-pull? Auto-train in GWR speak.
You'll need a driving trailer.
Ffestiniog ran them for a while, using a diesel loco.
Rob G
Madog & Mersey Railway (SM32)
Re: NEW FWLR LINE
Oops! Belatedly looked at Rik's link.
Anyway, found an FR pic:-
[attachment=0]FR95-103.jpg[/attachment]
- Attachments
- FR95-103.jpg (95.96 KiB) Viewed 7011 times
Rob G
Re: NEW FWLR LINE
Thanks Rob for the photo. It's a great looking train.
But this is what I am meaning mate.
It does happen on lines. That is something I really don't want happening on FWLR, so that's why I am proposing the line to run like the photo I have put up. Do members think it's ok, to run the train backwards for a short distance out of the proposed station and then run it forward has should be.
Thinking about it now though. If I was to run it clockwise into the station, that's all I could run, clockwise. May have to look into it more, unless you all have some better ideas to do it.
- IrishPeter
Re: NEW FWLR LINE
Kurseong (DHR), Killarney, Guisborough all have/had stations that were drive in and reverse/propel out (or vice versa.) Killarney used to be the most exciting of these as IE would cross the up and down Tralee there, so you had a class 141 and a rake of Cravens reversing into the bay platform, then an 071 or (new)201 arrive with a rake of mk.3s from Dublin. The signaller would exchange the single line tokens which were picked up on the fly as the trains departed for Mallow or revered into the headshunt to proceed to Tralee.
Peter in Va
Peter in Va
- RobRossington
Re: NEW FWLR LINE
For a couple of years after completion, WHR trains used to be dragged out of Porthmadog Harbour station by the pilot locomotive. The train engine would then couple up and take the train in the opposite direction toward Caernarfon.
There’s always a prototype
Re: NEW FWLR LINE
Hi Tom, if you look at the photo I have put up, you will see a long blue coming out from the track at the bottom of the photo to run around. There is also a small line going to the lawn, which is planned for the station. All I want to know is, does it matter if I was to reverse out of this and then carry on with running round the line.
Re: NEW FWLR LINE
If I interpret Rod's initial question correctly I think he means having a loco at one end of the train (irrespective of which way the loco is facing) and pulling the train from A to B then pushing it back from B to A without running round.
If this is not good practise can it be done with a loco centred between two carriages?
- RobRossington
Re: NEW FWLR LINE
Propelling is (on bigger railways at least) generally a no-no. Top and railing would be fine, as would something like an auto coach, where you have a driver up front.Peter Butler wrote: ↑Sun Feb 24, 2019 9:58 am If I interpret Rod's initial question correctly I think he means having a loco at one end of the train (irrespective of which way the loco is facing) and pulling the train from A to B then pushing it back from B to A without running round.
Re: NEW FWLR LINE
OK, Rod,
I guess you're proposing to reverse out of your dead-end station, past the junction to the "Limit of Shunt" and then forward round the turnout.
It sounds like you need to adopt DHR practice and run back & forth up their zig-zags.
Rob G
- IrishPeter
Re: NEW FWLR LINE
In a word - NOFWLR wrote: ↑Sun Feb 24, 2019 8:29 amHi Tom, if you look at the photo I have put up, you will see a long blue coming out from the track at the bottom of the photo to run around. There is also a small line going to the lawn, which is planned for the station. All I want to know is, does it matter if I was to reverse out of this and then carry on with running round the line.
Peter in Va
- IrishPeter
Re: NEW FWLR LINE
Killarney is probably the best known example in GB&I. There was also a second Irish example - Wicklow Town, but it has been gone for a long time. They were not that common in the UK thanks to the Board of Trade's aversion to reversing moves. Quite a bit more common overseas however.
Peter in Va
Peter in Va
