North Avenue Line
Re: North Avenue Line
its starting to look very industrial all the rusty bits are stuff scavenged from work and parts of a sawing machine I upcycled
- Attachments
- 20180412_175330.jpg (105.18 KiB) Viewed 5855 times
- 20180412_175315.jpg (87.6 KiB) Viewed 5855 times
- 20180412_175249.jpg (97.95 KiB) Viewed 5855 times
- 20180412_175312.jpg (88.12 KiB) Viewed 5855 times
- 20180412_175237.jpg (101.37 KiB) Viewed 5855 times
- 20180412_175234.jpg (107.54 KiB) Viewed 5855 times
- 20180412_175230.jpg (102.54 KiB) Viewed 5855 times
- 20180412_175224.jpg (94.07 KiB) Viewed 5855 times
- 20180412_175210.jpg (94.81 KiB) Viewed 5855 times
I found the verspa type scooter in the tiger shop
- Attachments
- 20180412_175204.jpg (98.5 KiB) Viewed 5855 times
- 20180412_175159.jpg (99.3 KiB) Viewed 5855 times
- 20180412_175156.jpg (108.69 KiB) Viewed 5855 times
- 20180412_175155.jpg (110.03 KiB) Viewed 5855 times
- 20180412_175151.jpg (100.84 KiB) Viewed 5855 times
the gas works still needs a roof and the signel box needs its roof finishing too. unfortunately the spray stone on the gas works steams to of failed it started to come off may of been damp when I sprayed it on .iv sprayed it over a few evenings its stopped it coming off anymore but I will keep an eye on it
- Attachments
- 20180412_175100.jpg (133.92 KiB) Viewed 5854 times
- 20180412_175113.jpg (96.61 KiB) Viewed 5854 times
- 20180412_175121.jpg (95.57 KiB) Viewed 5854 times
- 20180412_175129.jpg (100.75 KiB) Viewed 5854 times
the track has been pined down with copper pins and joints cleaned and tested.the railway is mounted on scaffold boards rased off the ground. iv got a few more lights to install the same as the one behind the man reading the paper on the pallets. I will also put lights in the signal box.
- Attachments
- 20180412_175135.jpg (97.96 KiB) Viewed 5853 times
- 20180412_175151.jpg (100.84 KiB) Viewed 5853 times
all the names on the line are based on real places .bartlow south .is a reference to bartlow a small village near castle camps where I grew up it had a railway running threw it but sadly not anymore. south deans is from the caravan park where my mum and dad used to holiday in great Yarmouth .the MXP part of the gas works is from one of the company's on the business park where I do a lot of work although they are nothing to do with gas I just liked the look of the MXP lettering
Excellent industrial line Jim. Love the lights by the way, very cool.
Great pics - very industrial! I can smell the rust
Thanks for the comments with the nicer whether on the way I hope to make more progress this week
made a small office to do on one of the platforms im going to build
- Attachments
- 20180420_215504.jpg (264.74 KiB) Viewed 4969 times
- 20180420_215500.jpg (202.91 KiB) Viewed 4969 times
- 20180420_215456.jpg (213.81 KiB) Viewed 4969 times
- 20180420_215450.jpg (196.92 KiB) Viewed 4969 times
- 20180420_215411.jpg (172.64 KiB) Viewed 4969 times
- 20180416_220453.jpg (175.63 KiB) Viewed 4969 times
- 20180416_220454.jpg (165.71 KiB) Viewed 4969 times
- 20180416_220458.jpg (163.69 KiB) Viewed 4969 times
- 20180416_220506.jpg (162.9 KiB) Viewed 4969 times
- 20180416_220503.jpg (178.38 KiB) Viewed 4969 times
made from palsticard .the doors are wood burnt with a gas soldering iron .the render effect is from modellers filler I had left from another project. again this building is made too look old and worn out .my line had a lot of buildings like this im trying to get the line to look old and worn
What a cool little railway.
Looks like your'e succeeding Jim.
bit of track laying this weekend had a little helper too
- Attachments
- 20180616_122719.jpg (131.04 KiB) Viewed 4741 times
- 20180616_122735.jpg (129.86 KiB) Viewed 4741 times
- 20180616_201213.jpg (283.67 KiB) Viewed 4741 times
- 20180616_201220.jpg (146.14 KiB) Viewed 4741 times
the line runs end to end and all works iv got to hide some of the wires and put some slate on the building roofs .had the train running tonight for a few hours with no problem il try and upload a video
the line runs from end to end all works fine I had the train running for a few hours tonight with no problems ,iv got to put some roofs on some of the buildings and then this small part of the line will be finished .
- Attachments
- 20180616_201213.jpg (283.67 KiB) Viewed 5702 times
- 20180616_201220.jpg (146.14 KiB) Viewed 5702 times
- 20180617_203635.jpg (109.6 KiB) Viewed 5702 times
- 20180617_203737.jpg (116.98 KiB) Viewed 5702 times
- 20180617_203743.jpg (131.43 KiB) Viewed 5702 times
- 20180617_203802.jpg (99.06 KiB) Viewed 5702 times
- 20180617_203833.jpg (111.97 KiB) Viewed 5702 times
the train stops at one and then switches to reverse and then does the same again and again.
I will try and upload a video later
- Attachments
- 20180618_195637.jpg (227.14 KiB) Viewed 5699 times
- 20180618_195644.jpg (184.03 KiB) Viewed 5699 times
- 20180618_195705.jpg (289.66 KiB) Viewed 5699 times
as you can see its all very rusty and worn
- Attachments
- 20180618_195655.jpg (181.57 KiB) Viewed 5699 times
- 20180618_195714.jpg (228.23 KiB) Viewed 5699 times
- 20180618_195722.jpg (244.23 KiB) Viewed 5699 times
