The Cockatoo Creek Tramway
Re: The Emerald and Gembrook Creek Tramway in 16mm
I liked the 1st plan too.
- Mitch stack
Hi Folks. the reason why i changed the plan is because of money. i can only afford so much for my line and the final plan is it will end up as a L shape as mentoned earlier.
Mitch.
Mitch.
We all have a bit less money Mitch, well most of us anyway lol. I can see now how it will end up L shaped, take your time and expand when you can.
I myself have had a suggestion to run double track, for which i will when i can save some money, it wonβt cost has much hopefully because most of it has been done with my two passing loops.
- Mitch stack
Thanks for the suggestion. ill consider it.
Mitch.
Mitch.
- Mitch stack
Hi folks. i have a minor update regarding the track instead of using the peco track i am going to use LGB track simply because its cheaper over here in Australia then getting the peco track shipped over here to Australia from dream steam.
i have ordered some IP engineering ezee kits to get a small train going for my MSS/Mamod loco i own, a Garden rail magazine subscription for 12 months and a association of 16mm ngm membership for Christmas. i have been given some track of a friends old garden railway i will hopefully collect before Christmas and have fun laying a L shape if i have enough to do so in the garden.
Mitch.
Mitch.
I prefer 45mm, there's plenty of easily accessible trains for younger enthusiasts. Says a man who has 6 playmobil trains. It also gives a multitude of track power options if you like.
- Mitch stack
Hi folks. heres the updated track plan for the line as an L shape with an addition of a 2 road steam up bay and 3 road carriage shed.
Mitch.
Mitch.
- Mitch stack
ive gotta more then agree on your statesman on 45mm. a few friends model 45mm and i thought 45mm would be the best way to go.
Mitch.
Mitch.
Your updated track looks brilliant Mitch, I myself run 32mm, but it doesnβt matter gauge you run for me, itβs all brilliant...Looking forward to you laying your track and some photoβs..Have a great day.
Hi Mitch,
Have you not considered using Sunset Valley code 250 45mm from Argyle.
- Mitch stack
Hi folks. I have not considered using sunset valley track from argyle thanks for the suggestion. im looking into building a battery loco similar to a narrow gauge mine loco using a IP engineering chassis kit.
mitch
mitch
Could be very interesting Mitch, looking forward to the build.
45mm gauge is probably a better idea in Aust. If you've already been given some LGB, you may decide to continue with the heavy rail. It doesn't look as good, but is close to indestructible.Mitch stack wrote: βSun Dec 03, 2017 7:41 am Hi folks. I have not considered using sunset valley track from argyle thanks for the suggestion.
Argyle also do Accucraft 'Euro' track which is more or less LGB compatible. You also have a couple of other retailers of garden track up your way.
'Branchline' at Croydon sells LGB track and can probably get Peco SM45 track in to order.
There's also 'Trains for the Garden' in Silvan, who sells LGB, Piko which is LGB compatible but a little cheaper and AusRail, which comes as LGB size rail and sleeper units to assemble into flex track. I've never been there, so no idea what is actually in stock, but the price lists are on the website.
- Mitch stack
I know trains in the garden that is where a mate gets his track from.
i will ask branchline about the LGB track when im next in there.
Mitch.
Mitch.
The drawback that LGB rail has, giant rail profile, is only when it is new and shiny. Within one year or so the shine is away and the track gets dark brown/ black in colour. Then the big rail profile is not obvious anymore.
I made several radii of R1 track, by sawing the plastic joints between the ties on one side of the track and bending the R1 settrack open in a vice. You can make any type of curves that way very cheap, because the R1 settrack is not wanted that much and very cheap to buy. That way you can make a gentle bent inwards when you enter a curve, making it look very natural. The trains like it also, certainly when you run with live steam loco's.
And you don't need to be very precise with your trackbed, since the track doesn't bend under the weight of your locomotive it smoothens out irregularities in the bed.
one little thing on your layout plan: There is a very sharp curve with a counter curve directly behind it. I would try to avoid that by adding a straight between the curves or make the transitions easier by using homebent settrack.
Cheers, Daan.
Cheers, Daan.
"En schΓΆne Gruess" from an Alpine railway in Holland.
I do like your updated version. It looks like it will be a nice layout to run on and is easy to extend should you want to.
What is the software you use to create the plans?
- Mitch stack
Hi there. i use anyrail 6 the free version to do my track plan.
Mitch.
Mitch.
Thanks.
- Mitch stack
Hi folks. Ronan AKA cooltrain and i did the final plan for the EGCT last night. as well as figuring out what stock im wanting/needing for my line.
the locos are
1 MSS 0-4-0 (already got)
2 Ip engineering simplex.
3 Roundhouse Sammie.
4 Roundhouse Lady anne Brunswick Green,Radio control and insulated wheels.
and 17 wagons for my line.
heres the track plan for those interested. Hope you enjoyed this post.
Mitch.
the locos are
Mitch.
That looks like a nice selection of engines and stock. Always good to have a wish list.
