With the rebuild completeits now time to do some fine tuning and finishing touches. The test run at the club track was a good start but there was still something not right. Further examination back on the bench showed that the lubricator hadn't been putting oil in, no wonder it was barking so loud ! This was traced to a piece of grit in the check valve allowing steam back into the lubricator. The hot shower when starting was also a problem so I've fitted automatic drain cocks.
These are mostly based on Dave Watkins' fitted to his Chaloner but altered to be at 90 degrees instead of in line. Since the track visit ive run the loco on blocks for about 5 hours, should have really done this before taking it as its got rid of alot of the initial stiffenss. The next track test is in about 4 weeks where hopefully I will get round without stopping
Dan's Rob roy rebuild
Dan,
DLR
www.freewebs.com/dlrail
DLR
One last update. During the last run there were some draughting issues confirmed, the loco wouldnt maintain pressure while running. In an attempt to solve this, the chimney has been sleved and a lempor style blast nozzle fitted. Another very succesful test was done at the club this evening, the loco completing several non stop laps with everything working as it should.
Dan,
DLR
DLR
Re: Dan's Rob roy rebuild
Hi
I have just picked up a Rob Roy and am interested in fitting the Auto drain cocks was this an easy job to do?
Paul
Paul
Does your Rob Roy have any kind of drain cocks fitted at the moment?
