Dan's Rob roy rebuild
LnBmad
Post by LnBmad » Wed Feb 11, 2015 4:03 pm
Nice work dan
If it can be made full scale it can be made 16mm
My line: http://gardenrails.myfreeforum.org/about7200.html
Post by Big Jim » Wed Feb 11, 2015 11:13 pm
Having just read the entire thread I have to take my hat off to you Dan. That is one serious rebuild. I was particularly amused/astonished by the white gunge in the water tank. I have seen some interesting bodges in my time and that is a good one.
I look forwards to seeing pics of the engine when finished.
DLRdan
Post by DLRdan » Sun Feb 15, 2015 10:58 am
Bit more progress, the buffer beams have been painted along with the cylinders. All the other parts that fit to the chassis have been given a coat of primer. Unlike the prototype I am going for the full passenger livery which is a lined blue with purple valences and cylinder covers.
Dan,
DLR
www.freewebs.com/dlrail
DLRdan
Post by DLRdan » Wed Mar 04, 2015 3:19 pm
Progress is slow but still continuing. The boiler and smokebox are bolted and sealed together, ready to go back in the frames. The cylinder covers have been fitted and the buffers are painted ready for lining. No pictures today but might have some pictures of new paint tomorow.
Dan,
DLR
DLRdan
Post by DLRdan » Thu Mar 05, 2015 9:00 pm
As promised, the first parts of blue are coming out of the paint shop. The cab roof is also painted in black, won't be long till the first fire :D
Dan,
DLR
DLRdan
Post by DLRdan » Mon Mar 16, 2015 11:07 pm
Bit more progress to report, the steps and boiler bands have been lined and varnished and lining has begun on the first tank.
The new insulation has also been added to the boiler.
Dan,
DLR
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Mon Mar 16, 2015 11:13 pm
Fantastic work Dan!
Post by Soar Valley Light » Tue Mar 17, 2015 7:26 pm
Very good indeed, I very much look forward to seeing the progress of re-assembly.
Well done and thanks for sharing.
DLRdan
Post by DLRdan » Thu Mar 26, 2015 8:43 pm
Yet more progress has been made but first, I realised that this thread started with a pile of bits and there was no picture of the loco as it stood. I went in search of one and found this taken shortly after I bought the loco.
Back to present day, Both tanks have had the white lining applied and are just awaiting the black inner. I've finally found a set of crests so the transfers will be applied shortly.
There was also a major step in reuniting the boiler with the frames after refitting the cleading and boiler bands. Since this photo was taken all the boiler fittings have been replaced.
Dan,
DLR
Post by Big Jim » Thu Mar 26, 2015 9:07 pm
That is very impressive Dan. What are you using to do the lining?
DLRdan
Post by DLRdan » Thu Mar 26, 2015 10:52 pm
Thanks Jim. I'm using a lining pen. Its relatively simple to use but takes a very long time, the outer line on one side of the cab took me 2 hours this morning.
Dan,
DLR
Post by Big Jim » Fri Mar 27, 2015 12:00 am
The results look worth it though.
Is it a Bob Moore pen or a bow pen?
DLRdan
Post by DLRdan » Sun Mar 29, 2015 10:03 pm
It is the Bob Moore pen, I've got a book that uses bow pens more or less throughout however a friend said he had much better results with the Bob Moore pen. Today marked the end of the painting with the last coats of varnish applied to the body work.
Dan,
DLR
DLRdan
Post by DLRdan » Sun Apr 05, 2015 9:53 pm
After a very long day of nuts, bolts and trapped fingers the rebuild is finally complete ! I didn't take any pictures during the assembly, it was pretty straight forward apart from getting the tanks in which took a little inginuity.
https://www.youtube.com/watch?v=0gi9hQGS2JQ
The star was the last thing to go on, its a familiar sight on most Caledonian locos but is often left off the models. Yesterday was the steam test which im pleased to say it passed with flying colours. Only a short video as I'm rather out of practice so was struggling for a steam.
WARNING: in the video below there is a gas burner with a terrible howl, don't have your sound up loud.
https://www.youtube.com/watch?v=REpWm-HfYY8
Dan,
DLR
Post by Big Jim » Sun Apr 05, 2015 11:47 pm
Well done Dan, she looks great.
DLRdan
Post by DLRdan » Tue May 12, 2015 5:18 pm
With the rebuild completeits now time to do some fine tuning and finishing touches. The test run at the club track was a good start but there was still something not right. Further examination back on the bench showed that the lubricator hadn't been putting oil in, no wonder it was barking so loud ! This was traced to a piece of grit in the check valve allowing steam back into the lubricator. The hot shower when starting was also a problem so I've fitted automatic drain cocks.
These are mostly based on Dave Watkins' fitted to his Chaloner but altered to be at 90 degrees instead of in line. Since the track visit ive run the loco on blocks for about 5 hours, should have really done this before taking it as its got rid of alot of the initial stiffenss. The next track test is in about 4 weeks where hopefully I will get round without stopping
Dan,
DLR
DLRdan
Post by DLRdan » Tue Jun 30, 2015 12:03 am
One last update. During the last run there were some draughting issues confirmed, the loco wouldnt maintain pressure while running. In an attempt to solve this, the chimney has been sleved and a lempor style blast nozzle fitted. Another very succesful test was done at the club this evening, the loco completing several non stop laps with everything working as it should.
Dan,
DLR
Paul3484
New User
New User
Re: Dan's Rob roy rebuild
Post by Paul3484 » Wed May 22, 2019 8:18 pm
Hi
I have just picked up a Rob Roy and am interested in fitting the Auto drain cocks was this an easy job to do?
Paul
Post by Big Jim » Wed May 22, 2019 9:49 pm
Does your Rob Roy have any kind of drain cocks fitted at the moment?
