Disasters, Out-takes, Accidents, Fails etc.
Re: Disasters, Out-takes, Accidents, Fails etc.
Here's a minor fail from a would-be running session this afternoon...
Over the last few days I've been doing a variety of jobs around the garden, but this afternoon I took a bit of time out to rectify some dodgy points at Penlan and clear the track as far as there so I could test out my handiwork.
Unfortunately, my test train was only halfway there when this happened:
From my vantage point on the other side of the garden, at first I couldn't work out what had happened - there was no obvious obstruction. A closer look revealed that a scenic lump of rock had fallen across the train and just caught the ducket on the brake van:
I'd moved the rock when I repainted the wall a couple of days previously - I guess it was precariously balanced and the gentle rumble of the passing train was enough to dislodge it...
Alas, the train never did make it to Penlan - the loco's batteries died just a few yards from the scene of this minor disaster! I'll try again tomorrow...
- dewintondave
I did everything right, but still...
Some stainless angle from an old inkjet printer was pressed into service to make an ash pan. A test braze with my high temp silver braze took well using the butane canister blow torch.
Let's give it a go However when the real thing was attempted with the Sievert going full bore on domestic LPG..
Best wishes,
Dave
Dave
Nicely modelled piece of lineside scrap you've created there, Dave!
- dewintondave
All my fails end up a scrap, why throw them away?
- RobRossington
That’s it... nicely does it, you’re nearl.... oh! B*llocks!
- dewintondave
I was supposed to be cutting a concave surface for the dome base. But I got my maths reversed and produced a convex surface
This is how it should have looked
Best wishes,
Dave
Dave
- dewintondave
We had just coasted down the return curve after another marvellous ascent and then the cylinder gently fell off...
Best wishes,
Dave
Dave
Oh!! OK, just as well it was nothing important LoL.
Seriously can happen to anyone Dave. At a guess as the cylinder oscillates, its been unscrewing the pin. The spring seats gripping on the face perhaps.
- dewintondave
Shhh, don't tell the inspector that I've posted this!
This is what happened when I tried to hastily rearrange the wood store to make it more photogenic for his visit - it's lucky he wears a hard hat! Kind of him to take the brunt of it too, largely sparing my nice new bolsters...
Have a good day,
Have a good day,
- dewintondave
Oh snap! I had a good one too yesterday
New loco running happily, then the coupling pin lifted and the loco started pulling on the gas line. The loco dragged the gas cylinder off the flatbed and was skidding along the track until it dug-in, and pulled the gas line off the cylinder, fire out. The loco was still chuffing along and the gas cylinder was happily discharging into the atmosphere. No harm done, I just need to keep an eye out for the coupling pin riding up
Best wishes,
Dave
Dave
- gregh
I put together a short video of some of my crashes over the years.
Greg from downunder.
Wow Greg, they are some really nasty, horrible ones there. I would have been crying for days....
I think we have all had those disasters. My Grandson did it with my Billy on our very first line and I was horrified at the time...It's like riding a bike don't you think, "you can't ride one until you fall off"
A slight change of words but:
There are two types of people in the world, those that crash model trains, and those that don't run model trains"
- RylstonLight
When I assembled a pair of Brandbright hopper wagons I wanted a slightly wavy edge to the steel side as though they were battered. I couldn’t work out how to do this with the supplied laser-cut plywood sides so went to some trouble to make up styrene-sheet replacements before using a heat gun on them to distress them slightly. The first (furthest away from camera) was a catious attempt and captured the effect I aimed for; the second (nearest camera) suffered from over-confidence when a few seconds too much heat concertined the side instantly.
The narrative is that it took a tumble down an embankment, but I am sure that HMRI would insist that it would be retired. However since they havn’t visited since the opening inspection . . .
Andy
Andy
I would call that a triumph, not a disaster.
- RylstonLight
It took a lot of work to make acceptable From above it is revealed just how buckled it is
Andy
Aaaaaahhh!!!! Shall I put you on the Inspectors list for a visit then, Andy?RylstonLight wrote: ↑Sun May 17, 2020 5:09 pm However since they havn’t visited since the opening inspection . . .
BTW, I do like your rusty weathering effects.
