Endon Valley make them for me, a sheet of WHR, NWNGR and sample numbers. I'm sure if you mention it to Tom (and quote my name), he'll print off a sheet and maybe introduce as a product.
Thank you, drybrushing is now my preferred technique.
You've certainly cracked that bit then!
I'm using Bernard Rocket's drawings for overall dimensions, but not the detail, which appears to be pretty inaccurate - just had to redraw the windows, for example. I hope it comes out ok...
Thanks Rod!FWLR wrote: ↑Mon May 24, 2021 8:55 am One little tip of you want it Andrew. If you want your planks to look like they are different lengths, try to score them vertically without going through them, you will be surprised how well they turn out and they do look like they leave a more natural look. You can use a flat screwdriver and give it a tap with a light hammer.....
In the nicest possible way Andrew - shouldn't there be a chicken or two in the windows? I really need to document some of my freelance scratchbuilds. This thread (which I have only just read in it's entirety) is an inspiration - Thanks to you, Peter B and J Morg.
Thanks Andrew. I really need to finish the inspectors report first. As my signature says, I'm a bit sporadic!Andrew wrote: ↑Tue Jun 22, 2021 9:53 am I keep forgetting I started that, then when I did about in the cupboard looking for something else I come across it and think "ooh, there's a Welsh Highland brake van..." I'm leaving it until I can (hopefully) finish it in one go.
Glad you've enjoyed the thread. I must admit, I sometimes look back through to remind myself what I've done over the years, it's a little like keeping a diary, but I've never been good at that. Do start a thread for your projects, I love reading about what others are up to...
