Ah, OK, fair enough! I'm a little younger, so my memory's sort of the opposite. I travelled to Salisbury from Waterloo a fair bit in my mid-teens, when the trains were hauled by 50s (which I rather liked, and still do), and later 47s. The 33s, which the bigger diesels had displaced, would occasionally be required to stand-in on their old role, which gave them the air of the plucky underdog. Well, to me, anyway...BertieB wrote: ↑Thu Jun 03, 2021 10:35 am I didn’t really want to own up to this but — I remember them replacing Bulleid Pacifics (!) — I mean, come on — and hanging around being totally reliable but extraordinarily boring (and just about the only locomotives to be seen locally) for the next 20 years. I reserve the right to be disappointed.
Semi-scale BR: The Modernisation Plan
That looks Great! Gives me inspiration to do some more Gauge one Compartment Coaches with all the panelling. Which does mean some Isle of Wight stock (now that will be good to see).
Jon
Jon
Current Projects:-
Rebuilding the Railway!
Current Projects:-
As always, it features a couple of totally avoidable, sloppy mistakes and, preoccupied with avoiding any issues negotiating tight curves, I’ve gone and coupled them way too far apart (and yes I did test it). I’ll need to fiddle with that. I’ll have to write ‘concentrate’ on the back of my hands for no.3.
I think they’ll be fine trundling round the garden though. And they do look big.
They may look big but they also look very good, and impressive
Those are really very nice indeed, love the detail!
I'm not the only one thinking "Annie and Clarabel" though, surely? I'm guessing the livery will be a coat of Sodor orangey-brown?! "Duck" will need to go green, of course...
Thanks guys.
Certainly not! Obviously, this obscure branchline has to be somewhere not too far from Weymouth. They had loads of Pannier tanks — and green coaches. Huh!
Well Bertie, whatever the faults and mistakes, they will only be visible to your eyes. Really good looking stock
Phil — Thanks very much. Now that I’ve calmed down, I guess I’m happy how they’ve turned out. Had to do quite a bit of remedial work (and sand away a fair bit of filler) on no.2 though. Cheers!
Isn't it annoying to spend money on something which you turn into dust and blow away? (Thinks - entrepreneurial idea - sell packets of dust for people to blow away, cut out the hard part!) Have I missed anything?
There’s now a video of ‘will they cope with the curves in the back garden’ posted in the Video forums here: https://gardenrails.org/forum/viewtopi ... 4&t=13576
Now you've established that you can't reduce the gap further, are you going to reinstate the buffers? They could be shortened if necessary, I'm sureBertieB wrote: ↑Sun Jul 18, 2021 12:39 pm There’s now a video of ‘will they cope with the curves in the back garden’ posted in the Video forums here: https://gardenrails.org/forum/viewtopi ... 4&t=13576
Still pretty certain buffers would get in the way on tighter curves, I’m afraid. But underframe, bogies and coach ends will all be painted murky black and I’m prepared to find it difficult to notice (as usual) that there’s anything missing.
The first two coaches of the 2021 Modernisation Plan now have a couple of coats of Agreeable Green — malachite — possibly not accurate but then neither are the coaches.
I’ve read that the Southern and then the Southern Region often re-varnished older coaches, rather than repainting them, so a variety of greens could be seen well into the BR era. That’s my excuse. They’d probably be so grubby you wouldn’t be able to tell anyway.
DIY inkjet transfers (on white decal paper) can be a bit of a faff, as you need to match the background on which they’ll be applied. Middle picture shows varied Photoshop swatch samples, based on a scan of the painted background colour (plasticard off-cut, top picture, right), from my cheapo HP printer/scanner. ‘Scan 2’ (middle picture, far right) seemed a reasonable match.
Bottom pic shows the printed A5 ‘page’ of the required items, using the background green chosen. I’ll need to touch up all the white edges after application.
You can get decals with transparent backgrounds professionally printed to order, of course, but unfortunately they’re rather expensive.
(This is what I do now on a Saturday night)
Cheers!
Yes, thats what I've done in the past as well. Touching up the edges I always find to be an unsatisfactory 'mare, so I'll be fascinated to see how you do it.
The coaches themselves are looking fabulous, of course.
Those coaches really looking good in their livery. I too will be following the decal story with interest. I've been using white self adhesive vinyl for my crests up to now and have a similar problem matching the background to the livery.
I use a guy in USA called Stan Cederleaf for my decals. Waterslide on a clear background, but due to his equipment it prints white. Provide your own design or have him design for you. At around $60.00 for a A4 sheet not cheap, but he will fill the sheet and they are very good. This is an example:
- Attachments
- Railbus-Finish-4.jpg (74.17 KiB) Viewed 8499 times
While searching for self adhesive, Welsh red Dragon stickers I came across this on eBay:
https://i.ebayimg.com/thumbs/images/g/K ... l1200.webp
He will print any design you ask and is not expensive. I had some made and they are just what I wanted.
Search..... greenteagraphics in eBay for further information.
- Sylvian Tennant
They are fantastic mate.
I'm also looking into majing my iwn decals. What program do you use is it just the normal word/paint pages/drawing ones
The splodgy mess around the transfers is a protective coat of Humbrol Clear I put on after they had dried. The following day I could paint over it as necessary. I suppose I should have printed them to the width of the panel and door
The decals / transfers worked out fine. Colour match wasn’t too bad and, of course, there were scruffy white edges but I hadn’t trimmed them too tightly and there was plenty of space to tidy up with a small paint brush.
With the whole coach then spray varnished, I think they look OK. But after all that, these livery details are quite small and restrained — outside, I don’t suppose they’ll be particularly noticeable (as you can see in the picture below).
Thanks for all the interest. JimmyB’s guy in the US offering bespoke transfers (including white print) on transparent backgrounds, all for $60 an A4 sheet is the cheapest I’ve heard of. However…
I’ve been using ancient, legacy, print design software — particularly Photoshop (versions that came on install discs) — on elderly Macs for ages, which isn’t really of much help to you.
If you want to match backgrounds or aim for specific colours, you’ll need image editing and / or graphics applications that let you work in CMYK* (because your printer does) and that offer precise control of colour, type, imported images and sizing. You could sign up to Creative Cloud — it’s only 50 quid a month! But no doubt there are cheaper alternatives.
(*CMYK - cyan, magenta, yellow, black - are the inks used in colour printing and colours are defined by their percentages, in that order)
Cheapo inkjet printers / scanners can be amazing value (I’d recommend HP) but the colour is never absolutely accurate, which is why I go through the whole palaver of doing a set of swatches / colour samples — including slightly darker, lighter, warmer, cooler alternatives to the scanned colour I’m trying to match (as shown in the earlier photograph). I don’t think there’s a better way to assess colour accuracy, than printing out the colour (on the decal paper you intend to use) and holding it against the original. But sometimes that doesn’t work either.
Best of luck!
Sylvian Tennant wrote: ↑Mon Aug 09, 2021 11:18 am 'What program do you use – is it just the normal word/paint pages/drawing ones?'
Best of luck!
Users browsing this forum: Sam95 and 3 guests
