IP Engineering Rail Bus
Re: IP Engineering Rail Bus
Thanks guys. I've been meaning to get some decent decals for my stock. I've tried vinyl which is ok, if viewed from a distance with eyes half closed. I might try decal printing paper - thanks for the tip, Philip. But if all else fails, I'll give Cedarleaf a try.
Rik I do have decal (ink-jet) printing paper, water-slide (clear and white) and also rub-on, they are okay, but IMHO some colours come out "thin" and after lacquering before applying can have thick edges. Its all right for one-off, but I the professional ones take some beating.ge_rik wrote: ↑Tue May 11, 2021 12:51 pm Thanks guys. I've been meaning to get some decent decals for my stock. I've tried vinyl which is ok, if viewed from a distance with eyes half closed. I might try decal printing paper - thanks for the tip, Philip. But if all else fails, I'll give Cedarleaf a try.
Thanks chaps. Those on the railbus do indeed look splendid. As Eric Morecambe would say, "You can't see the join".
That's really looking good, well done... I'm quite tempted...
Looking good Jimmy.
My I ask why you chose to use a separate ESC rather than one of the Deltangs with it built into the receiver?
A very tidy job compared to some of mine!
Looking forward to the video.
You took the words out of my mouth - almost in that order as well. In my case substitute 'most' for 'some'
So between the showers I managed to get out for a quick test run:
https://youtu.be/y5gclhbc448
Even with the weight added, it is quite light and is affected by any unevenness, nut still fun
That looks great, and you have a wonderful garden setting for it too!
Really enjoyed following the build and it's great seeing it released into the wild! Looks superb.
Many thanks for all the kind comments, on close inspection there are areas where I "could try harder" but it passes the 6 foot rule and I am happy with it
I have just updated my blog, for those wishing to see the full build:
http://www.tumble-down-falls.co.uk/ip-e ... g-railcar/
Thanks for detailing your build from start to commissioning run - something I think I am yet to do
Unfortunately, they're no longer in production, and extremely hard to find, anymore.
Consequently, I'll be using the same Rx and ESC combo as Jimmy, in some coming projects; they appear very simple to set up.
Marvelous work, Jim. Must say the blog is really nicely done, too.
Looks very much at home on the railway. I added weight to my Ford railbus with white metal seated figures but they were 1:19. Not sure if there are any suppliers of 1:20.3 seated white metal figures ....
Philip, apologies I missed your question, but Aaron has answered it correctly, also with the Deltang there can be some fiddly soldering, one false slip and it is £60.00 gone, these are pre-wired, and plug and socket.
