invicta280 wrote: ↑Fri Jun 12, 2020 2:34 pm
"...I'd suggest one or the other. Green or Black. Malachite? BR green?"
I’ve stared dozily at the thing in primer for weeks – and then gone for another interpretation of ‘large logo’, BR mixed traffic, lined black (as usual), which makes sense, sort of. It’s not an express passenger engine, after all.
Tank engines don’t generally get named but clearly the chaps at Waterloo decided this class were special enough, so it’s from the ‘Distinguished Literary Figures associated with the Southern Railway Area' class (they’ll have come up with a snappier title than that). Predictably, as you can see, this one’s ‘Jane Austen’.
Lining and graphics done in Photoshop, assembled into an A4 ‘page’, exported to PDF and inkjet printed on to white decal paper. Had to be careful (and quick) not to cause ‘stretch marks’, when applying the particularly long decals (the ink and varnish surface can split revealing the white layer underneath, if you fiddle with them for too long). Fortunately I’d printed off duplicates. A lot of white edges to touch up afterwards, unavoidably.
R/C still to be fitted, should be here soon, one hopes.
If some of Bulleid’s bonkers reinventions of the (British) steam locomotive had been properly developed and in service, who knows... Perhaps British Railways might have removed the ‘air-smoothed’ cladding in the mid 50s, or built BR Standard 0-4-4-0s and 0-6-6-0s?
Now there’s an idea for another one.
- I’m assuming the panels between the bogies incorporate lift-up flaps, allowing access to the ashpan and other gubbins hiding down there
- 1_WW_91A.jpg (219.49 KiB) Viewed 4210 times
- Wilco rattlecan black; inkjet printed, Photoshopped decals; matt varnish
- 4_WW_85A.jpg (251.89 KiB) Viewed 4210 times
- Difficult to photograph without it looking like a murky black blob; hence the added 'brightness'
- 3_WW_67A.jpg (258.44 KiB) Viewed 4210 times
- Love the curved sides on Bulleids. The Brighton-designed Standard 2-6-4T has them too, which I imagine isn’t a coincidence
- 5_WW_77A.jpg (161.84 KiB) Viewed 4210 times
