Glendale Rocket Project.
Tony Bird
Re: Glendale Rocket Project.
Post by Tony Bird » Sat Jan 20, 2018 10:25 am
Hi Grant,
I wonder would a little more friction to the centre axle help. Could a little roller deflecting the drive band down slightly between the second and third axle work, though not wanting to get away from the simplicity of the project which is part of its attraction.
A very good idea and perfectly possible but alas not with the chassis as it stands as the motor would need to be moved a little, maybe when I have a go at Mk.2 I will try it. I have used a jockey pulley but in my a case sprocket to take up the wear on a chain drive electric locomotive chassis, the chain had worn but not enough that a link could be removed.
I have however improved the traction of the chassis, when building steam locomotives I usually balance them around the centre of the distance between the driving wheels. This usually requires a weight to be fitted to the front or rear buffer beam to achieve a rough balance. When I picked up the model it was very heavy at the back because of the batteries the motor not anything like balancing them. The hasn't happened before as all the chassis I have made have had the weight between the axles not outside.
So I balanced the model on its centre axle.
IMG_3626 LR.jpg (58.14 KiB) Viewed 5347 times
It needed three and a half lead washers to balance the model.
IMG_3627 LR.jpg (60.2 KiB) Viewed 5347 times
These washers were glued into the smoke box and then painted
IMG_3632 LR.jpg (79.92 KiB) Viewed 5347 times
This done the model would stay in place with both front and rear buffer beams touching the table.
IMG_3628 LR.jpg (58.59 KiB) Viewed 5347 times
IMG_3629 LR.jpg (62.05 KiB) Viewed 5347 times
The traction now is such that the motor will stall before the wheels slip. The Glendale Rocket now easily manages to pull both carriages and pushing it two Thomas the Tank Engine carriages as well. I have always found balance my steam engines improves their traction but never thought of trying the same on electric locomotive, to be fair most are probably nearly in balance anyway.
Regards Tony.
Post by LNR » Sat Jan 20, 2018 10:57 am
Good one Tony, I guess the basics of good loco design apply right down to your tiny locos size.
Tony Bird
Post by Tony Bird » Wed Jan 24, 2018 12:50 pm
Hi,
As we go away tomorrow for a bit and I had got to a convenient stopping point with the boilers I am working on so to fill it time I thought I would do a bit of work on the Glendale Rocket Mk.2. Starting with cutting the body about to see if it was possible to fit thee AAA cells in the same place as Mk.1 had two.
This was a none electric version of the Glendale Rocket.
IMG_3590 LR.jpg (32.86 KiB) Viewed 5306 times
The roof was removed along with the wheels and the first cut made.
IMG_3648 LR.jpg (78.47 KiB) Viewed 5306 times
The body was dismantled.
IMG_3649 LR.jpg (92.74 KiB) Viewed 5306 times
Part of the chassis was cut away.
IMG_3650 LR.jpg (88.71 KiB) Viewed 5306 times
And filled to shape.
IMG_3651 LR.jpg (74.76 KiB) Viewed 5306 times
Leaving it looking thus.
IMG_3652 LR.jpg (74.17 KiB) Viewed 5306 times
The inside of the body had almost all the fixing points removed.
IMG_3653 LR.jpg (90.44 KiB) Viewed 5306 times
Other parts of the model replaced.
IMG_3654 LR.jpg (85.19 KiB) Viewed 5306 times
The body assembled with battery holder fitted.
IMG_3657 LR.jpg (83.79 KiB) Viewed 5306 times
Body at end of play.
IMG_3656 LR.jpg (72.26 KiB) Viewed 5306 times
So it looks as if I will be able to fit R/C to this model but it will be some time before it is completed as when we return it will be to finish the boilers.
Regards Tony.
Tony Bird
Post by Tony Bird » Tue Feb 06, 2018 2:23 pm
Hi,
Having spent some time away I have been catching up with some drawing of things made that I might what to make again. I have also edited some video which has been added to the video of the Glendale Rocket, this video shows the Rocket performing after it had been balance and pulling both carriages.
https://youtu.be/gA5uMe0zN90
It will be several more weeks before we return to the UK and back to the workshop.
Regards Tony.
Post by LNR » Tue Feb 06, 2018 9:33 pm
What a difference balancing makes, enjoy your break away Tony,
Tony Bird
Post by Tony Bird » Sat Mar 10, 2018 5:21 pm
Hi,
I have been back from far away places for a bit
not sure I like the temperature here though.
I have part made a chassis for the Glendale Rocket Mk.2 it is much the same as Mk.1 though it has a slightly shorter wheel base and is an 0-4-0 which gives a little more room. There is more weight to balance the extra battery in the smoke box and a slightly larger motor is fitted.
IMG_4130 LR.jpg (96.44 KiB) Viewed 4968 times
I might get some more done tomorrow.
Regards Tony.
Tony Bird
Post by Tony Bird » Mon Mar 12, 2018 1:20 pm
Hi,
Mk.2 Glendale Rocket has been painted and assembled but will have to wait until I can afford the R/C.
IMG_4134 LR.jpg (67.46 KiB) Viewed 4923 times
IMG_4151 LR.jpg (62.08 KiB) Viewed 4923 times
IMG_4152 LR.jpg (67.18 KiB) Viewed 4923 times
Regards Tony.
Tony Bird
Post by Tony Bird » Thu Mar 15, 2018 5:04 pm
Hi,
The radio control arrived today and was fitted this afternoon.
IMG_4158 LR.jpg (50 KiB) Viewed 4876 times
Video at:
https://youtu.be/zD0oVv7Ji_g
It works quite well on just 3.6 volts but I think 4.8 would be better as I use in one of my other conversions, I might try a smaller motor.
Regards Tony.
markoteal
Post by markoteal » Thu Mar 15, 2018 5:13 pm
Thanks Tony - great example , especially your very neat wiring! Beats my mound of spaghetti I seem to amass in my builds!
