Use dehumidifier water, or distilled water DO NOT use de-ionized water. It will try to "leach" chemicals out of your boiler, lots of science out there that will explain a lot better than I can. Whatever water you use, filter it, I use coffee filter papers, keeps all the little particles out.DafyddElvy wrote: ↑Mon Jun 07, 2021 10:47 amMy brother tells me only use either rain water or dehumidified water, tap water especially in england contains all sorts of chemicals we don't want in the boiler, that's about the sum total of my present knowledge.
David
New Live Steam Owner
Re: New Live Steam Owner
- DafyddElvy
This link has some useful information
http://www.nmia.com/~vrbass/steam/stmintro.htm
What I need to find now is suppliers for bit and preferable in Central Scotland, what does seem illusive is a Korean gas valve adaptor, pictured, the only one I can find is from China and wouldn't arrive until early July.
I am slowly pulling together a list of things I need which I'll share for comment when its closer to complete.
David
David
- Attachments
- Korean Gas Valve Adaptor.jpg (12.83 KiB) Viewed 3437 times
I bought bone of these from Amazon, and it did not work, the gas refused to be dispensed. After a few conversations I bought another one, different supplier, (same type) and it works perfectly.DafyddElvy wrote: ↑Mon Jun 07, 2021 10:16 pm This link has some useful information
David
- DafyddElvy
[/quote]
Jimmy,
I don't suppose you have the details of the company or the make for the valve you have?
David
[/quote]
Jimmy,
David
https://smile.amazon.co.uk/gp/product/B ... UTF8&psc=1 This is the one that workedDafyddElvy wrote: ↑Tue Jun 08, 2021 7:17 amJimmy,
David
- DafyddElvy
Jimmy,
David
[/quote]
[/quote]
Jimmy,
Thank you for that link, who'd have thought the first piece of equipment I would buy for a garden steam loco would be a gas valve, thanks.
That made me remember the first thing I would always get ready for a 7 1/4" operating day would be to soak a tampon in paraffin the night before, I won't go in to the purpose of a tampon but they are ideal for lighting minimum gauge engines.
Anyhow, I digress, back to pulling together a list of items I need.
David
David
[/quote]
[/quote]
Jimmy,
David
- DafyddElvy
Do I need a special tool to adjust the safety valve on an Accucraft loco?
David
David
- DafyddElvy
Sea Lion has landed and my wife says it looks braw, but its not coming in the bedroom.
I now need to think about conversion to RC control, I'd rather not have have a transmitter similar to the aeroplane folk but something that would fit in my hand, a quick web search found https://www.rctrains.co.uk/ which uses a deltang hand set with an RC trains receiver. Has anyone else used the deltand with a receiver to control a live steam loco?
Is their another similar system out there that I should consider?
As always any and all advice much appreciated.
David
David
David,
As you know, there have been a number of recent mentions about Deltang equipment on the Northfields Tramway thread https://gardenrails.org/forum/viewtopic ... ng#p163362
Rik ( Ge_Rik) started RCTrains a few years ago before passing the business on to Phil Partridge, who is also a member on her.. David Theusison (sp?) ("Mr Deltang" ) was the original developer and supplier of the modules and their abilities, but the products were retailed by a number of other companies, including RC Trains.
The current lack of components therefore affects every one of those retailers equally, unfortunately.
There are various phone based systems around and there are many aircraft type systems but personally I'm not aware of anything that compares to Deltang. So unless you care to dig around in the hope of finding the odd Tx and/or Rx from various sources you will have to wait until Micron manage to get their planned alternative up and running. The queue for that I imagine will stretch around the block!!
Rik also did some experimenting with a DIY system a while ago, but abandoned it as far as I know.
Andy at Micron now has the MR001, which is a replacement for the DT Rx102, and is for use with live steam. I have used this Rx but for battery powered so cannot comment on the steam aspect. If you contact Andy, he is very helpful.philipy wrote: ↑Fri Jun 11, 2021 7:20 am David,
- DafyddElvy
I have spoken with Phil at RC Trains this morning and a way forward for my own requirements agreed.
Thanks all the feedback and suggestions.
David
David
- artfull dodger
Welcome to the world of live steam. One upgrade guys tend to put on these and many other engines is a replacement safety valve from Anything Narrow Gauge. These are made in the USA by the leader of my local steam group, then Jay K from The Train Dept works with Simon to get them to the UK. They are a proper Pop style safety instead of the stock ones that tend to weep wisps of steam instead of blowing off then resetting properly. Various pop off pressures are available. Thankfully here in the states, we dont have to worry about boiler certs and testing, even for public shows for boilers that operate at 3bar or less. Only the ride on scale engines with steam pressures in the lethal range have to get those done. If its a brand new model, the certs for the boiler and gas tank should be with the rest of the paperwork, or even on a used engine that the previous owner kept all of the paperwork. Good luck and enjoy! AD
