Gauge 1 ‘project’
Re: Gauge 1 ‘project’
Garethh, GMES has now reopened after the last lockdown and our next open day is the 13th. I'm planning to be running on the Gauge one (I'm the one will all the small electric mice) if you wanted to come say hello! We're a lovely bunch and always looking for more members!
Jon
Jon
Current Projects:-
Rebuilding the Railway!
Current Projects:-
Thanks Jon, I’m planning on becoming a member just waiting for new year when hopefully funds will allow! May well try and pop down on the 13th though, always fun to watch some trains!angr607 wrote: ↑Tue Dec 01, 2020 6:49 pm Garethh, GMES has now reopened after the last lockdown and our next open day is the 13th. I'm planning to be running on the Gauge one (I'm the one will all the small electric mice) if you wanted to come say hello! We're a lovely bunch and always looking for more members!
Jon
Managed to borrow a propane torch to get the crank web silver soldered, then cut out and cleaned up the center bit of axle, drive axle is now complete and back in the frames.
Made a start on the cylinder last night, first step was to face off a chunk of brass in the 4 jaw down to the correct dimensions
Then the bore center was center popped and set up in the 4 jaw in the same way as the eccentric
Then opened up gradually with drills until the boring tool could fit in
Next I bored it out to 3/4” on a fine feed taking very light cuts at the end
Where I’m at now, bore finish is pretty good but it’s going to get lapped just to be sure. Next stage will be drilling the passageways and turning the end covers.
- -steves-
Looking superb, love the live photo's. Please do keep us up to date with this as it is without a doubt right up my street.
Started drilling exhaust ports and steam passages this afternoon, pretty terrifying but luckily everything lined up nicely!
Front cylinder cover is done, just waiting on a 1/8 reamer before I can crack on with the rear. Quick question for anyone with experience, the book suggests fitting lever operated drain cocks, I remember seeing auto ones on the djb site but they don’t seem to be there anymore. Has anyone used them or know how/if they work?
I've not used automatic cylinder drain cocks, but there is a description and some drawings in the files of steammodelloco16mm.groups.io if you are a member.
I'm not convinced they are necessary with slide valves, but I guess they would stop most of the oil and water going up the exhaust pipe when starting off.
It’s a relatively large single cylinder and by all accounts the can suffer quite badly from hydraulic lock without draincocks of some kind fitted. My thinking was that auto ones would save chasing the loco to shut them once it’s managed to get started! I’m not a member of that group unfortunately, have managed to find some drawings for larger scales so know how they work, just a little unsure what sort of dimensions to use use when scalining them down for a 3/4 bore!
Bit of progress since the last post, rear cylinder cover and piston gland all made up, as per the book. With the piston I decided to fit a silicone o ring rather than the graphite yarn packing described in the book:
Made a start on the steam chest, using the same technique as the cylinder block:
- Attachments
- 904C8B98-F0B7-4F2E-993E-04A2CADBD79A.jpeg (237.12 KiB) Viewed 6952 times
Made a bit of progress since the last post, valve chest and valve are now finished
Followed by a test fit in the chassis, happily it all turns over nicely!
All becomes quite a tight fit once the trunk guide gets involved though so will have to be very careful where I drill the cylinder for mounting...
Also made up the drain cocks pretty much as per the drawings, still may have a pop at some auto ones at a later date
Also skipped ahead a bit and made the lubricator body, because I fancied doing some silver soldering mostly
- -steves-
Looking very nice indeed, mine always turn out very rough looking and shabby
- artfull dodger
Very nice workmanship!! Wish whoever in the UK that built the Project I have would have done that kind of work, and only wish I had the tools and skills to remake a few things like the whole cylinder block assembly. Mine was poorly done and looks like a hack job compared to your fine work. Keep the pics coming as you make progress! Mike
Thanks for the kind words, it’s far from perfect though, I think the photos are flattering! Fingers crossed it works! I’d be interested to see some photos of yours if it’s up and running? The cylinder block isn’t actually as daunting as it seemed, if you have access to a lathe with a 4 jaw and a small pillar drill it just takes a bit of thought and care. There’s a couple of suppliers in the uk that make a drop in cylinder unit alternatively.artfull dodger wrote: ↑Thu Jan 07, 2021 4:52 pm Very nice workmanship!! Wish whoever in the UK that built the Project I have would have done that kind of work, and only wish I had the tools and skills to remake a few things like the whole cylinder block assembly. Mine was poorly done and looks like a hack job compared to your fine work. Keep the pics coming as you make progress! Mike
Gareth, I do think you are "under selling" yourself, there is some very fine workmanship there.
- -steves-
Totally agreee
- artfull dodger
Here is a pic of her on the bench, railway is mostly mud and trackwork needs some leveling and joints unkinked for gauge one running. Mine will be getting SDJR transfers from Barrets in the UK, so its in the deep blue color now. I am planning to get a complete new smoke box assembly as this one is all soldered and I want the front cover removable for sealing things, missing the petticoat so she is not drafting as well as needed and lacks the smokebox door casting. A friend has the shop tools, so since I have the book, I may make the attempt with his help to remake the cylinder block/crosshead tube assembly to a higher standard than she has now. I will see how she runs when spring weather arrives. My boiler bands are just black zip ties right now, need to make up proper brass ones but this works for now. Missing the ladders on the engine and tender still as well, gotta make those as well.
I appreciate the positive words, just trying to not get carried away until I know it at least runs on air, if it doesn’t work then it doesn’t matter how pretty it looks!
Thanks for sharing the photo, nice to see a finished one and it’ll definitely look the part in sdjr blue, as far as I’m aware that’s the only prototype colour that’s not black!artfull dodger wrote: ↑Sat Jan 09, 2021 6:48 am Here is a pic of her on the bench, railway is mostly mud and trackwork needs some leveling and joints unkinked for gauge one running. Mine will be getting SDJR transfers from Barrets in the UK, so its in the deep blue color now. I am planning to get a complete new smoke box assembly as this one is all soldered and I want the front cover removable for sealing things, missing the petticoat so she is not drafting as well as needed and lacks the smokebox door casting. A friend has the shop tools, so since I have the book, I may make the attempt with his help to remake the cylinder block/crosshead tube assembly to a higher standard than she has now. I will see how she runs when spring weather arrives. My boiler bands are just black zip ties right now, need to make up proper brass ones but this works for now. Missing the ladders on the engine and tender still as well, gotta make those as well.
Did I detect hi-vis trousers in one of those photos?
