Charles - Penrhyn Mainline Hunslet
- Hydrostatic Dazza
Re: Charles - Penrhyn Mainline Hunslet
Super stuff. Enjoying you sharing the process.
- dewintondave
I'm doing a steel smokebox again, as steel is what I have. I'll paint it internally this time.
Here's the marked-out front plate. Who else uses their digital calipers for scribing lines?
Best wishes,
Dave
Dave
Guilty! Nice to see some progress on this!dewintondave wrote: ↑Wed Sep 08, 2021 4:35 am Who else uses their digital calipers for scribing lines?
Hi Dave,dewintondave wrote: ↑Wed Sep 08, 2021 4:35 am I'm doing a steel smokebox again, as steel is what I have. I'll paint it internally this time.
Do you use 16 gauge on this type of project?
Do you paint internally with gal?
Thanks Tim
- dewintondave
It's 1.6mm Tim, I'll just use ordinary household oil based enamel. The last one wasn't coated with anything except steam oil for a year before I started coal firing
Best wishes,
Dave
Dave
- dewintondave
This end-of-workbench clamp makes sawing sheet a pleasure
Best wishes,
Dave
Dave
- dewintondave
Starting off the smokebox door hole with a holesaw, the rest had to be bored out
Best wishes,
Dave
Dave
- dewintondave
Progress shot! After lots of boring, sawing, and filing. I love all that stuff
Best wishes,
Dave
Dave
When properly engineered, even the simplest of parts are a joy to look at.
- dewintondave
They do AaronOld Man Aaron wrote: ↑Fri Sep 17, 2021 1:00 pm When properly engineered, even the simplest of parts are a joy to look at.
Here's the back plate from 4mm hot rolled steel. I wanted it thicker to engage better with the boiler shell. The profiles were scribed from the front plate. The hole will be a lot bigger
Best wishes,
Dave
Dave
- dewintondave
That's a big hole for the boiler barrel, turned in the lathe on a faceplate. I'm just sawing off the excess before grinding and filing to profile. I used the bench grinder, very satisfying. Lots of checking with the digital caliper to get the curve even
Best wishes,
Dave
Dave
Very tidy - and a damn sight quicker than chain-drilling and filing!
- dewintondave
Whatever it takes to get the job doneOld Man Aaron wrote: ↑Wed Sep 22, 2021 3:05 am Very tidy - and a damn sight quicker than chain-drilling and filing!
Checking the fit with the boiler barrel material, I bought that about 10 years ago from Macc Models, for this model
Best wishes,
Dave
Dave
- dewintondave
Marking out the smokebox wrapper, needing to saw off a thin strip to true up the edge
Best wishes,
Dave
Dave
- dewintondave
Turning down the bending radius for the smokebox wrapper. I used this for forming the Large De Winton boiler shell in 2006!
Best wishes,
Dave
Dave
- dewintondave
Here's the first build log. The rolling chassis
Best wishes,
Dave
Dave
- dewintondave
- dewintondave
Fitting the smokebox to the frames, and a start on the cylinders
Best wishes,
Dave
Dave
