Added Regner Lanterns to my RH Billy
artfull dodger
Post by artfull dodger » Fri Feb 09, 2018 5:21 pm
Added some Regner lanterns to my RH Billy. Front one is lighted with a bulb, powered by a 9volt battery mounted in a holder under the cab and a toggle switch mounted in the cab floor. Rear one isnt lighted yet. I plan to get a center off SPDT toggle so I can manualy flip between the front or rear lantern. Wire the front is a piece of stiff Teflon wire bent to look like a conduit. The loco itself is the ground side of the circuit. The Aussie look is out for now, the Austrian look is where I ended up going. O&K builders plates and square numbers(sort of like the ones on the LGB Stainz) are on the order books of Narrow Planet. I went with the nice round O&K builders plates with red and black inlay finish. I want to get the vacuum pipes for the front and rear as well. Working on a center buffer to mount above the LGB loop couplers. The Roundhouse goodies have to wait till I have room on my credit card to place that order.
artfull dodger
Re: Added Regner Lanterns to my RH Billy
Post by artfull dodger » Fri Feb 09, 2018 11:13 pm
Post by tom_tom_go » Sat Feb 10, 2018 12:17 pm
I like the lamps, nice warm glow.
Slomo proving it's worth in the video as well.
Post by FWLR » Fri Mar 02, 2018 9:08 am
Very nice looking engine indeed. :thumbright:
