Post
by Old Man Aaron » Thu Oct 21, 2021 9:17 am
Keith S wrote: ↑Mon Oct 11, 2021 3:17 pm
I find it quite amusing that S16 flatly refuses to post bits to Canada under any circumstance but WILL post them to Australia!
Likely some sort of product liability insurance bull***. I think Binnie doesn't ship to the Yanks for the same reason. Sent you a message about it..
Beautiful work as always, Darrell. Love the elegant-yet-rugged look about the loco. Great little whistles, those.
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Mon Oct 25, 2021 9:08 pm
Neat pipe runs make an impression. Captain Plod needs to learn how to do this. Some research at the ME and forum library and one full day spent so far on this, more days to come, but if all goes well it will be useful for decades to come. Repurposed some old Alloy plate and what ever is to hand.
IMG_6974 by
Darrell McCulloch, on Flickr
IMG_6972 by
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Fri Oct 29, 2021 8:46 pm
A bit more done to the tubie bendy thingie. I think it will be a tool that evolves as needs require.
IMG_7013 by
IMG_7017 by
IMG_7020 by
IMG_7022 by
IMG_7023 by
Handy little fella.
IMG_7021 by
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Sat Oct 30, 2021 9:00 pm
Inordinate amount of Saturday time for this plumbing. I expect I will get better at it with more experience.
IMG_7031 by
IMG_7032 by
IMG_7034 by
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Sun Oct 31, 2021 8:38 pm
Sorting the electron path from the tender to the loco, hidden under the 5mm high cab timber floor boards (to be made later) to the servo mount then to the receiver up front in the tank via 4 x 4 x 0.5 Knupfer brass tube. The cab/tanks lift clear with disturbing anything.
I think it is tidy, facilitates maintenance/repairs. Just fitted after much head scratching, cutting , filing and soldering and test runs. I will be using 22 swg silicon wires and JST connectors (and these do fit) The white bell wire is just for the pic.
IMG_7042 by
IMG_7044 by
IMG_7045 by
IMG_7046 by
IMG_7047 by
Post
by Old Man Aaron » Thu Nov 04, 2021 3:05 am
That's a damn tidy wiring run!
Congratulations on the boiler ticket, too. Absolute proper job.
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Thu Nov 04, 2021 7:08 pm
Old Man Aaron wrote: ↑Thu Nov 04, 2021 3:05 am
Thanks.
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Thu Nov 04, 2021 7:51 pm
An evening of shortening servo wires, fitting new Futabo connectors. There are constant mutterings emanating from Captain Plod, "Must finish this loco, must finish this loco., must finish ....."
IMG_7094 by
IMG_7096 by
IMG_7097 by
IMG_7099 by
IMG_7100 by
IMG_7101 by
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Sat Nov 06, 2021 8:39 pm
Captain Plod breathes a sigh of relief. He can have a break from the wiring issues and servo installation. At least until programing throw limits and other such witchcraft. Now to lower the kettle into the frames and plumb it up. Cab /tank lift on and off with disturbing any thing. The thoughts are there will be more room for fingers and such like in the next build with will be 5".
IMG_7119 by
IMG_7117 by
IMG_7116 by
IMG_7111 by
IMG_7109 by
IMG_7110 by
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Fri Nov 12, 2021 7:04 pm
The white bronze head light castings arrive from NZ. It is inspired by the large Queensland Railway Kero head lamps of the 1920s.
IMG_7136 by
A modified SLR models Darj head light slips inside.
IMG_7137 by
IMG_7138 by
An evening of delicate milling and filing had it sliding on and off the mounting bracket
IMG_7187 by
IMG_7169 by
IMG_7168 by
Drill and tap the smoke box
IMG_7191 by
IMG_7190 by
pandsrowe
Post
by pandsrowe » Sat Nov 13, 2021 10:39 am
That is quite a sizeable headlight, what will you be powering it with, servo batteries or something else?
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Sun Nov 14, 2021 8:17 pm
pandsrowe wrote: ↑Sat Nov 13, 2021 10:39 am
It is scaled to the big Kero headlights used in Queensland.
It has a modified SLR models Darj head light that slips inside. These have pill batteries and we have used these for our evening runs for some time with much enjoyment.
Photos of them in use in here some where
viewtopic.php?f=41&t=11430&start=630
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Sat Nov 20, 2021 7:47 pm
The works staff had to lower the fire door opening in the dry back head 5mm due to interference with the superheater connection. Accurate mistakes via 3D CAD. It seem it was a senior management mistake. Saturday was make a fire door our of stainless with an infill piece of copper.
IMG_7261 by
IMG_7263 by
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Sun Nov 21, 2021 7:59 pm
3,942 jobs to go...
IMG_7270 by
Post
by ge_rik » Mon Nov 22, 2021 7:52 am
A really neat bit of remediation. It's hardly noticeable.
Hydrostatic Dazza
Post
by Hydrostatic Dazza » Wed Nov 24, 2021 7:08 pm
Fitting some fittings
Boiler number on a brass plate
and also stamped on the dry back head
and a crown level plate, just for kicks and giggles.
Trimming fibre washers and also added various copper shim sheets to the store's drawers for making washers.
IMG_7322 by
IMG_7320 by
IMG_7321 by
Post
by Old Man Aaron » Fri Nov 26, 2021 12:01 pm
That's some tidy work. Always a pleasure to see.
