Thanks Don, I have a head start with Brass and Silver brazing, I have been involved with making steel bicycle frames for 40 years now.
Llewellyn Loco Works #1
- Hydrostatic Dazza
Re: Llewellyn Loco Works #1
- Hydrostatic Dazza
Why progress is slow on the little loco and the "Potters Orchid Railway" I around the 12.30 mark talking to engineering legend Peter Olds. I was fireman on 967 for the day. I had a drive with 8 on the hook the next day.
https://www.youtube.com/watch?v=v1O4DHw ... DxwQeklH9w
Nice video, like the locos.
Don
Don
- Hydrostatic Dazza
A simple job started, but it was nice to be in the Red Room last night with ABC jazz on the radio working on my little choo choo.
- Hydrostatic Dazza
A little package arrived at the Llewellyn Locomotive Works from "Stannier Engineering" yesterday.
The workshop manager studies the smoke box saddle casting in his usual pensive manner as the head hand tries to get his head around it. Nice fella but dim at times.
Cast in White Bronze this new investment casting looks sweet.
- Hydrostatic Dazza
In the drought stricken Queensland (all of Australia) there is progress on the front foot plate.
Holes all drilled and 10 BA threads done.
A bit more milling and it will be done.
Hi Dazza
That casting looks very good. Did you make a master first? That will be bolted down onto the footplate you are making all looking very neat,
Don
Don
- Hydrostatic Dazza
I draw the part in 3D and checked all in my full assembly model. Every part is done this way and then converted to a 2D workshop drawing. I drew another 3D part with some machining allowance added and then sent that file (STL version) to Mike at Stannier Engineering in NewZealand and he prints the wax part and the foundry make the shell mold with the wax and then do the investment casting. Then the postman delivers it to my door. The process takes 2-3 weeks. I have done this for the steam chest covers and the expansion link supports. Pics of this earlier in this thread some where. This all takes time but when the loco is completed and running there will be a full set of proven and accurate drawings for every part, without all the made up bits and vagaries and ommissions that I have have suffered in previous drawings.
- Hydrostatic Dazza
1001 uses for small cut off discs. I simply love em.
[/quote]
[/quote]
Thanks Dazza. I didn't realise they could print off the wax part from a drawing to such quality. I know people have been 3D printing master but thought these needed a fair bit of cleaning up.
Don
[/quote]
Don
- Hydrostatic Dazza
Don, go here
https://www.flickr.com/photos/151366293 ... 945260417/
for examples of the detail possible, note the small text on the castings.
The possibilities opening up are immense for model engineering.
- Hydrostatic Dazza
At the world wide head quarters of the Llewellyn Locomotive Works the drawing staff generated a plot to chain drill the front foot plate. It may seem fussy but it makes the final hand filing smooth and easy. One has to love DRO on the mill drill.
After zero progress on the little loco and the POR garden railway it was nice to bolt this part on with 8 BA hex. No slotted screws are allowed to be seen on the exterior of this loco.
Saddle casting and the completion of the cab foot plate are the next steps, then the smoke box so the boiler can be trial fitted to the frames.
- Hydrostatic Dazza
Clean up the bottom of the new smoke box saddle casting.
I do not spot through, I clock off a true edge and use the DRO. Sanity marks before using the DRO.
Trimming the 10 BA hex bolts.
Fit up
Fit up
- Hydrostatic Dazza
The head fitter and his side hand , or rather paw are pondering the smoke box. The drawing office has generated the required drawings and the materials are to hand.
- Hydrostatic Dazza
Chain drill the cab foot plate via DRO
The loco crew called into the erection shop and had a look over the loco and made some comments about how some of servos will get under foot when they are fitted.
And finding somewhere to place the Gas tank as well as the servos.
Lovely work. I assume you find chain drilling a better option than milling a slot.
Don
Don
- Hydrostatic Dazza
This fella will be coal fired for the full experience and atmosphere.
I have a servo under the front foot plate for the cylinder drains. The reverser one will be in the half length R/H tank. The throttle one will have to be on the foot plate. I am also contemplating a servo to flip the fire door, to have better control of firing, cool the fire when standing or shunting. (in the cab) Not sure if it will be of any use but heaps of fun. Also one servo for the whistle which I hope to mount under the right side of the cab and the whistle is a pretend WHB air reservoir under the running board and tank.
I could mill, but the corners will still need a file unless you use a very small diameter cutter. I drilled and then filed it with the largest Mill files I had and checked it for dimensions and got all to 0.10mm . Filing is my daily work. It did not take long.
- Hydrostatic Dazza
In hindsight I would have recessed the front tube plate deeper into the boiler barrel so the smoke box could be attached in a more traditional method, of rivets, screws etc but ................... So I have have hatched a plan to use the super heater attachments to pull and secure the smoke box to the barrel. Unlike the original (vague) drawings I am going for a fixed smoke box/boiler to the saddle and allow the expansion back wards in the frames, as like full size locos. Fixed at the rear and expansion movement forwards into the fixed smoke box/saddle seems a strange way to do it ? ! Considering that joint will foul up, even seize with the muck in the box and or keeping the joint air tight for good steaming, it just did not make sense. A reminder it is all a design and metal working exercise for the locos to come. The material is LG2 bronze a friend had left over, in payment for this material I brazed up some more full size loco motion oil pots that were needed as spares for the Rattler's 974 and 967.
