Wild Rose ~ Quarry Hunslet
Re: Wild Rose ~ Quarry Hunslet
Looking forward to seeing this run.
Remind me, is it still able to be a dual fuel burner?
- dewintondave
Me too
Yes I hope to also fire it by gas or liquid fuel
Best wishes,
Dave
Dave
- dewintondave
I've just soldered in the water return pipes for the bypass valves. Hopefully the water won't shoot out of the filler
Best wishes,
Dave
Dave
Very neat job Dave.
- dewintondave
That's lovely workmanship. Something I could only admire and dream about doing.
- dewintondave
We're getting there, very slowly. Boiler feed fitted
Best wishes,
Dave
Dave
It's starting to look finished Dave, looking forward to seeing it run.
How long do you think before first test on your line?
Nice Dave….Very good bit of engineering that.
- dewintondave
Thank you chaps.
I'm not sure when it will be running on the line. I want to test the pumps against boiler pressure though
Best wishes,
Dave
Dave
- dewintondave
Pushing on with the blower. I drilled the nozzle 0.45mm diameter as my small Jacobs chuck couldn't grip anything smaller
Best wishes,
Dave
Dave
Good trick I learned from TonyW is to fill the boiler up with water until you get about 40 PSI and then open the blower.
If you get a nice fountain shooting out the chimney you know the blower position is going to be efficient!
- dewintondave
Splendid, a working saddle tank! It gives the little loco something special..
- dewintondave
I need to connect the to-be-built reverser to the reversing valve. eBay supplied some nice stainless 2mm Bowden cable inner that fits nicely in 1/8 K&S brass tubing it seems rigid enough for pull and push operation.
Best wishes,
Dave
Dave
- dewintondave
Before I can make the reverser I need to make the bodywork to see how much space is available for it. One side is now complete, the other is in progress.
The main panel is a piece of 0.6mm steel sheet bent around a 1/4" bar for the radius. The top piece is 1/4" x 1/16" strip brazed into a 90 deg angle. It's all soft soldered together
Best wishes,
Dave
Dave
- dewintondave
Second side completed on this hot Auckland Anniversary day
- Attachments
- IMG_20190128_162946.jpg (41.95 KiB) Viewed 6089 times
Best wishes,
Dave
Dave
Solid work, is steel easier to soft solder than brass?
- dewintondave
Steel solders very easily with zinc chloride flux
It was easier than soldering the copper/brass tank Tom
Best wishes,
Dave
Dave
