Wild Rose ~ Quarry Hunslet
- dewintondave
Re: Wild Rose ~ Quarry Hunslet
Thanks lads
I've been doing a paint test on ordinary household enamel paint. I tested this strip at 120, 150, and then 180 deg C for an hour each. The paint held up well, I mixed it from black and light grey which I have some old tins of. I'm finally going to paint the smokebox!. Look at the temper colour of the steel strip, it was shiny steel at the start. There was a light straw at 150 deg, and nothing at 120. My smokebox door drawbar has a light straw colour to it from the steam tests, but there's no colouration to the shiny smokebox front or door.
Best wishes,
Dave
Dave
- dewintondave
Well, I mixed-up my custom smokebox colour and have given it a coat. Here we are drying in the sun. I'll have to fire it to give the paint a good baking
Best wishes,
Dave
Dave
Very very pretty Dave. Suddenly when you get some distance you can see it as a whole rather than a collection of components. More power to your elbow .
Best,
Tom
Best,
Tom
- dewintondave
Thanks Tom!
Had an excellent run on the rolling road today - to bake the enamel Ran for over an hour
Best wishes,
Dave
Dave
- dewintondave
Very interesting results Tom. After lots of forward running I tried reverse, it's not as good in reverse, slows up. Lots of steam oil appeared in the exhaust outlet. The smaller steam pipe must be coated in oil, and then suddenly that became the exhaust, so all the oil enroute suddenly goes to wasteTom the blacksmith wrote: ↑Tue Oct 29, 2019 7:23 amHi Dave,dewintondave wrote: ↑Tue Oct 29, 2019 7:06 am The pipes are different sizes 1/8" for steam and 5/32" for exhaust when running forwards. We'll see if it makes any difference, it was to ease the flow of exhaust.
I thought that might be the case, as well as easing exhaust out you might be keeping inlet gas speeds high for good cylinder filling. I would be intrigued to hear what you find, please keep us posted. Love the buffers too!!
Best,
Tom
Best wishes,
Dave
Dave
- dewintondave
I have fixed-up all the old image URL's so all the images are viewable again in the first 7 pages. I've also removed the double signatures and made those first videos viewable again
Best wishes,
Dave
Dave
Great job done Dave. She is running really smoothly.
Agree with you, any excuse for a run of a steamer..
Very interesting Dave, I suppose you won't really be able to tell until running loaded on your railway. Did you do all the calculations to arrive at pipe size and cylinder bore etc? I might have missed it but what is the cylinder bore? And thanks for fixing the old pictures, I've really enjoyed re-reading this thread whilst waiting in hospital for my back op. Keep the updates coming,dewintondave wrote: ↑Mon Nov 25, 2019 6:58 am I have fixed-up all the old image URL's so all the images are viewable again in the first 7 pages. I've also removed the double signatures and made those first videos viewable again
Best,
Tom
- dewintondave
Tom, I doubled a single port area to make the steam pipe diameter. The cylinder bore has been a closely guarded secret...until now - 13/16" - 20mmTom the blacksmith wrote: ↑Mon Nov 25, 2019 8:47 am
Best,
Tom
I hope you are recovering now from your operation
I can't bring myself to do it Tom
Best wishes,
Dave
Dave
- dewintondave
I used CNC technology to produce the required radii for the dome, it was so enjoyable that an internal radius was generated too
Dome base -
Dome bore -
Superglued onto a mandrel. Many increments on the exterior, so quick to smooth with a file
Dome base -
Dome bore -
Best wishes,
Dave
Dave
- dewintondave
It was a lovely calm day today... First run on the line!
Started with 150mL water in the boiler and 300mL in the tank, at the end of the run there was 70mL remaining in the tank. Lots of oil was splattered about, 2mL of water was extracted from the displacement lubricator at the end of the run.
I was so excited I entirely forgot about the whistle!
Best wishes,
Dave
Dave
You should be wearing a big smile Dave, lovely smooth running even ( I presume) with the pump working. Top job.
Superb Loco Dave. A fantastic build and a really beautiful looking Loco to boot...
What a well mannered machine Dave, I'd be well chuffed if I were you, pun intended.
Sorry I wrestled that closely guarded secret out of you, that is big cylinder bore, larger than it looks. Is there a specific reason for choosing 13/16 bore?
This has been a really inspiring build dave, and thanks for taking the time to explain all the complex bits. Looking forward to more running in footage!
Best,
Tom
Best,
Tom
Well done Dave, those huge oscillating cylinders moving at a steady pace don't look that bad compared to a Mamod running at a speed of light.
Coal firing video next please.
superb loco !
- dewintondave
Thanks very much lads. I am well chuffed
Big cylinders are the secret to slow running TomTom the blacksmith wrote: ↑Wed Nov 27, 2019 9:28 pm Sorry I wrestled that closely guarded secret out of you, that is big cylinder bore, larger than it looks. Is there a specific reason for choosing 13/16 bore?
I agree that they don't look that bad either Tomtom_tom_go wrote: ↑Wed Nov 27, 2019 9:36 pm Well done Dave, those huge oscillating cylinders moving at a steady pace don't look that bad compared to a Mamod running at a speed of light.
Best wishes,
Dave
Dave
I am very impressed with this engine. Your usual excellent fit-and-finish and smooth running are extra-evident in this machine. At first I was astonished that you chose to use oscillating cylinders, but I have to admit I love the sinuous look this engine has as it moves along. It reminds me of an oscillating ship's engine I saw running on air at the Transportation museum in Lucerne.
I am curious about why you chose to have the exhaust right at the top of the chimney rather than employing a blast-pipe to draw the fire.
