Question to the collective wisdom as I progress the CAD drawings with regards to whistle material sizes.
Brian Wilson writes " the whistle itself is made from thin walled brass tube"
The diameter is 8.00mm but there is no mention in the text or the drawings of the thickness of "thin wall".
Does any one know of a suitable dimension for the thin wall that gives a reasonable tone ? .5mm, 1.00mm or ???????
Whistle and material dimensions ?
- Hydrostatic Dazza
Re: Whistle and material dimensions ?
Years ago whistles would have been made from 'treble tube', tube that had been drawn through the forming die three times, hence the name. I don't think that it is still available but I'm prepared to be proved wrong. I do know that the thinner the tube is the better the sound will be, please don't ask me the theory but I'm sure that others on this group will be along to explain. What I can say for certain is that I fitted a Regner whistle to my Accucraft Ragleth last year and I have been very pleased with the result, a very clear note not like some of the rather pathetic squeaks that I have heard on some locos.
I'm not at home at present but I will endeavour to measure the wall thickness of the whistle tube later on and post the result.
K&S brass tube is the modern equivalent to what LBSC referred to as treblet tube in his articles. I'm told it is triple drawn, certainly it is accurately sized and the inner surface is very smooth.
Thanks Graeme for the update on treble tube, I didn't realise that the K&S range of materials was produced to such standards.
Dazza, I've checked my Regner whistle and the tube not including the pipe fitting measures 58mm long, 10mm diameter and ~ 0.5mm wall thickness. Sorry I can't be more accurate but I can't find a way of gauging the tube thickness through the steam aperture, hence having to use a steel rule at an angle with the attendant inaccurate result.
