Jurassic models Baldwin cab back kit
JMORG
Post by JMORG » Fri Jan 12, 2018 6:36 pm
Hi guys,
Does anyone have a picture of the Baldwin cab back from Jurassic? Also (more importantly), do they still make them?
Re: Jurassic models Baldwin cab back kit
Post by Andrew » Fri Feb 23, 2018 7:45 pm
Hello!
Sorry, a little late in the day (I've not been around much!), but if it's still of use, here's the Jurassic Baldwin cab back:
Baldwin back.jpg (336.31 KiB) Viewed 2362 times
It's designed to slot right down into the bunker, but I had to modify it because that's where the RC kit lives on mine. The kit leaves you to sort the roof out for yourself too - not too much problem for a metalworker perhaps, but it took me several attempts to get right. I made a wooden roof in the end (with additional supports inside), not perfect, but it looks OK from most angles. Well, as far is it can look OK when the real thing looks like it's been made from the station master's potting shed...
I'm afraid I don't know whether they're still available...
Post by tom_tom_go » Fri Feb 23, 2018 8:45 pm
I remember you doing this Andrew, looks good to me.
A proper narrow gauge make do and mend!
Post by Big Jim » Sat Feb 24, 2018 11:23 am
Might be worth an email to Mike.
mike.jurassic@btinternet.com
