Wet exhaust coal firing
Re: Wet exhaust coal firing
Post by GTB » Mon Jan 22, 2018 9:27 am
tom_tom_go wrote: Sat Jan 20, 2018 7:17 pm Thanks Andrew, I think I will try lagging first before anything else.
Worth a try I guess...... Paint the lagging so the string is sealed, otherwise it just absorbs water and/or oil depending on where it is.
The Garratt has insulated steam lines and superheating and it is still the wettest loco I have. Second wettest is probably the Shay which isn't superheated, but the thing both have in common is very long external exhaust lines and more than two cylinders.
FWIW. I tallied up and half my locos have a flue superheater, while the other half don't and have external main steam pipes. I don't notice any major differences in wetness at the front end, although I don't run very often in temperatures below 20C.
With respect to cylinder drain cocks, have you considered fitting the exhaust intercepting valve that Roundhouse use on the Silver Lady. I assume they'd sell you one if you ask nicely and you already have your SL for reference to work out how to fit it into the steam pipes. No drilling, tapping, etc. and no clearance issues.
Post by tom_tom_go » Mon Jan 22, 2018 2:05 pm
It's interesting regarding lagging pipes as the non-forum people I have spoken either say it works and then some say it's pointless - argghh!
I did think about the Silver Lady exhaust block but it's not a simple install from memory or even possible, I need to have another look methinks.
I believe my situation is unquie as I am trying to run a coal fired loco on an end to end layout so I have to deal with even more condensate as the loco is not continuously running.
Mr Riverdale said that I can say from him to my wife that it is a shame not to run a coal fired loco on a continuous layout and that the land should be reclaimed back from the garden!
markoteal
Post by markoteal » Mon Jan 22, 2018 3:21 pm
Judging by his advice, Mr Riverdale is probably a customer of the famous welsh lawyer, Dai Vorse :lol:
Post by tom_tom_go » Sat Jan 27, 2018 6:31 pm
As the weather is so pants at the moment I don't mind this loco being out of service so I thought I would lag the pipes:
I will paint the lagging black I think (I know most paint it white but as the lagging is over scale to be more effective I don't want it standing out).
Post by GTB » Sun Jan 28, 2018 9:35 am
tom_tom_go wrote: Sat Jan 27, 2018 6:31 pm I will paint the lagging black I think (I know most paint it white but as the lagging is over scale to be more effective I don't want it standing out).
Neat work.
Ships and power stations have white steam pipe lagging. Can't say I've ever seen it on a full size working steam locomotive, although there are probably over restored 'preserved' examples out there...... :roll:
AFGadd
Post by AFGadd » Mon Jan 29, 2018 10:43 pm
Having seen the length of the steam line from the lubricator to the steam chest, I'm not surprised that you're getting a "wet front end"...
I will be amazed if that doesn't make some difference, TBH?
Keep us in the loop, please.
dewintondave
Post by dewintondave » Wed Jan 31, 2018 9:29 am
Hi Tom,
That's a long loop of tubing before the lubricator, I'm inclined to think it's unnecessary
Best wishes,
Dave
Post by tom_tom_go » Wed Jan 31, 2018 10:29 am
dewintondave wrote: Wed Jan 31, 2018 9:29 am Hi Tom,
I see your point mate but the reason it's like that is to allow for the whistle pipe work which I am going to redo and will possibly lag as well?
Post by tom_tom_go » Sat Feb 17, 2018 8:06 pm
Ready for testing:
The whistle pipe has been replaced with a new one so it does not show in the cab front window. The pipe lagging for the whistle is purely for show as it's much thinner than the steam pipe lagging you see in the pictures.
Post by LNR » Sun Feb 18, 2018 6:28 am
That looks well done Tom, like the black. I imagine there's a yard or two of cord in that lot.
AFGadd
Post by AFGadd » Sun Feb 18, 2018 5:57 pm
Looks good, and it can't possibly do any harm and will probably have a positive effect?
And either way, it looks great.
Post by GTB » Mon Feb 19, 2018 8:48 am
tom_tom_go wrote: Sat Feb 17, 2018 8:06 pm The whistle pipe has been replaced with a new one so it does not show in the cab front window. The pipe lagging for the whistle is purely for show as it's much thinner than the steam pipe lagging you see in the pictures.
Neatly done. The black lagging makes the pipework less obtrusive, but I'm not sure how long the cab floor on a coal fired loco will stay that colour...........
For what it's worth.......
I was running the Hunslet yesterday on the rolling road and did some measurements while I was at it. This loco is my usual lab rat and is a standard 45mm gauge Roundhouse Bertie with different bodywork. Fairly typical of most Roundhouse locos I imagine.
Even though it is 'superheated' it produces about 10ml of condensate as the cylinders warm up and then produces another 5ml or so of condensate over the rest of a 30min run, plus maybe 0.5ml of steam oil. When the smokebox door is opened drops of water can be seen regularly dripping off the base of the chimney and running down the exhaust pipes when running.
The cylinders are up to temperature within less than a minute of moving off under steam and when steam is shut off, the cylinder temp drops about 1degC every 10sec for the first minute or so. No extra drops of water were seen when the loco was stopped, reversed and started up again, say a 10 sec stop all up.
Post by tom_tom_go » Tue Feb 20, 2018 9:29 pm
Hopefully, these chaps will dirty the floor up soon:
Post by LNR » Wed Feb 21, 2018 1:34 am
Didn't your fireman like those bits of coal, thought he'd heave em out the back! :lol:
PS it's hard when you have to get non scale things like a coal shovel, into a scale cab!
Post by tom_tom_go » Sat Mar 10, 2018 9:14 am
LNR wrote: Wed Feb 21, 2018 1:34 am Didn't your fireman like those bits of coal, thought he'd heave em out the back! :lol:
The size of the coal pieces would not last five minutes in her fire!
I don't like the shovel so might change it for a Locoworks brass one I have which has been chemically blackened.
Maybe if I fit a tender he would be digging the right way :mrgreen:
Post by Peter Butler » Sat Mar 10, 2018 10:38 am
Regardless of the size of coal or shovel Tom at least you have figures in your locomotive whereas so many live steamers are runaways with no driver!
11thHour
Post by 11thHour » Fri Mar 16, 2018 1:45 am
I attach a drawing of a theoretical solution to Wet Exhaust.
I have done no experimentation on my theory, and have no qualification whatsoever in the field.
Per the drawing, the cylinder exhausts are joined at the lowest point by a T junction. the bottom of the leg of the T is blind but for a very small hole. (how small to be determined by experimentation) The theory is that the condensed water will accumulate at the lowest point of the T and be expelled by exhaust steam pressure. The hole must not be large enough to let excessive steam out.
An alternative would be to put a leg on each exhaust and not connect them.
Perhaps someone has tried this before? did it work?
Tim
Post by tom_tom_go » Fri Mar 16, 2018 11:59 am
Hi Tim,
I had a similar idea but this will impact the exhaust draft.
The hole needs to be temporary to clear the condensate so you would need a servo or lever to open and close it.
11thHour
Post by 11thHour » Sat Mar 17, 2018 9:36 pm
I was hoping to find a hole size which would not expel much steam but at the same time pressure the water that has condensed at the bottom of the tube. Maybe the water tension would prevent the water expelling through such a small hole?
Tim
Post by tom_tom_go » Sun Jun 03, 2018 4:09 pm
I am such an idiot.
You know that feeling when you re-read instructions and then the penny drops, well I did that this weekend and realised the replacement nozzles that are supplied by Riverdale for slow running I was fitting on the blower and not the exhaust! The blower nozzle has a tiny hole compared to the exhaust type and this nozzle has been sitting in my spares box for ages while I have been mucking about with exhaust nozzles for both blower and exhaust.
So now that is sorted the amount of condensate has reduced significantly.
