Faller railcar
Faller railcar
will soon be repainting a faller railcar which is plastic. Could anyone give me advice on preparing the plastic and also making the paint stick and not scratch off to easy? im hoping to use humbrol paints for the sides and a spray black for the roof. would a lacker be of use once painted or just a simple varnish?
cheers james
cheers james
If its not made to run on rails I'm not bothered
Hello!
I'm no expert, and it's been maybe 15 years since I did it, but the paint job on my Railcar came out well and seems to have stood the test of time, so, as I recall...
The body was stripped down into its component parts and then sprayed with ordinary car primer - red oxide as I recall... Then I brush painted the chocolate and cream livery in enamel - the first coat looked absolutely awful, but I thinned the next two coats and it all came out nice and smoothly. I'd possibly spray paint it now, but it seemed to work. I don't think I varnished it, but I should have done - not having an airbrush I generally use Humbrol spray varnish...
Good luck with it,
Good luck with it,
cheers for the replies. railcar has arrived and now ive seen it ive decided to keep it in the blue but add some detail colours in places such as the vents, pin stripe down the body, whiskers, seats and dash board. the roof will also be painted and the wheels (hopefully if it will stick)pictures of progress soon
cheers james
cheers james
Has anyone tried a black plastic dye?Andrew:109722 wrote:Forgot to say, if you find a way of making paint stick to the red plastic wheels do let me know!!!
Several years ago when I was into building up the 70's 4.5v and 12v lego classic locos, I found there was a massive oversupply of red wheels whereas the black wheels, needed for some of the models, were rare as hen's teeth and when available on BrickLink, commanded prices I was unprepared to pay. As I was not building brick-exact versions for collectors, but wanted the general impression of the model running on 4.5v, I was quite happy to fake the odd part to make things look generally right.
A lucky killing on eBay got me a black wheel-set I needed so I never took it further at the time, but perhaps this would at least tone down the red Faller wheels, more durably than an over-paint?
