ruined coal mine
ruined coal mine
iv decided a ruined coal mine would look good on my line.iv used left over wood from work the stonework is done the (peter jones method) this involves snapping off bits of basa wood gluing them on with pva then lots and lots of layers of glue after this I painted it with exterior house paint .I then mixed up lots of different colour paints of greens and darker shades and painted and sponged it on .its a ruin so I wanted it to look old and disused as possible the roof is bake been cans and this is made too look like its collapsed. the roof should rust up quite quick with a bit of help from the weather and some salt washing up liquid.iv stated to make the pit wheel and winding gear.
it will soon rust looks very shinny now and its a collapsed roof on an old building so its meant to look a bit dramatic after a few weeks outside and some washing up liquid and some salt it will rust and look a lot different .im still building the pit wheel and winding gear and will post some pictures up as im building it and will try not to OVER DO ANYTHINK
- Dr. Bond of the DVLR
- Retired Director
thank you mr bond.there going in the garden so will weather more with the wind rain snow etc .the pit wheel etc is jest as big as this building so will look quite dramatic on the side of my railway with a few nice stones rocks and some coal ashs from a fire and some more rusty bits of tin its going to look pretty good I think 90 per cent of my buildings have all been made in roughly the same way and so far there doing well some outside for 2 years with no problem other than a quick spray paint of a few roofs that need a bit of smarting up
thank you all for the comments .The PVA is some I picked up from the builders merchant got a massive tub as long as you buy decent PVA it will be fine outside no real need to use waterproof PVA in my opinion its all painted over anyway . at work iv used PVA to seal brickwork concrete slabs etc and always used builders pva and never had any trouble.i know some people like to use waterproof pva on there buildings so each to there own.iv used this method of stonework on a number of my buildings and it works well you jest have to build up the layers and be patient on the last few layers you have to let it hassel ie dry off a bit then go over it with the brush in the direction of the stones if that makes sense .I made a pub using the same method http://gardenrails.myfreeforum.org/about7648.html
- Soar Valley Light
Hi Jim,
That's an impressive piece of work. There are techniques there which need noting down for future reference. Thanks for sharing them.
I have to say I've worked at pits which were still turning but quite resembled what you've created!
Just a thought but have you considered adding a derelict Lancashire boiler at the back of the chimney? They were often outside in a Dutch barn type affair, it might add another dimension of reality. Of course, the boiler may be gone but the mountings and pipework still there. As I say, just a thought.
Keep up the good work and the supply of information and photos.
Users browsing this forum: philipy and 8 guests
