RWLR bogie flat wagons
Re: RWLR bogie flat wagons
This flat wagon has been hanging around the works for quite a while so started to try and make it into something:
It was bought off eBay as a job lot and was originally stuck to a plastic O gauge coach chassis which did not look right to my eyes as the wheels and bogie were out of scale for the size of the wagon. The planking I added using lollipop sticks then weathered.
I have some G scale bogies that I butchered ages ago to fit 32mm track so I removed the O gauge chassis and then cut off the bogie mounts and bolted these back on:
I made bushes from cutting lengths off a soldering iron tip:
Bit of a bodge I know but it's my bitsa wagon on the cheap so not my finest work!
Testing bogie in place, rotates easily and even rocks a bit so should run smoothly:
Outside to see if it runs freely which it does:
The bracing I have added is from a G scale coach with rivet detail.
- RylstonLight
The flat wagon is nice, but I love the buffer stop. Redolent of an impoverished company that presses anything half-way suitable into service. Excellent or though the erstwhile Mr Isle might have had a different opinion.
The steel billets started life as wagon loads but I then found other uses for them
That's a bit extravagant isn't ittom_tom_go wrote: βThu Mar 08, 2018 4:27 pm I made bushes from cutting lengths off a soldering iron tip:
A nice and very serviceable wagon, Tom.
Well I love it Tom, a very nice bit of ingenious use of materials and cheap I bet.
It's those bits and pieces you save that eventually come in handy one day (the soldering iron broke years ago).LNR wrote: βThu Mar 08, 2018 11:17 pmThat's a bit extravagant isn't ittom_tom_go wrote: βThu Mar 08, 2018 4:27 pm I made bushes from cutting lengths off a soldering iron tip:
they look fantastic
Great work - look the business - great for running BBQ food around the garden this summer!
Have to give it a run at your place then Mark as you are the BBQ king!
Deffo - we'll get a visit set up this summer - you do the driving and I'll do the burning!
Sounds good Mark.
Thanks to philipy for his 3D printing services I am able to use some spare choppers I have as couplings for this wagon:
Work has been keeping me from railway activities (although the sodding weather has not helped), however, I got round to changing the wheels on my first bogie wagon to curly spoked wheels I had in my bits box:
The bogies were supplied with 20mm plain disc wheels but I want some rolling stock with wheels that have more visual appeal (I use to like watching the spoked wheels on my Hornby wagons go round when I was even younger, little things and all that).
I had to drill out the centre holes on the curly spoked wheels from 2mm to 3mm to use the axles that were provided with the bogies. I did this using a hand drill (professional bodge) and I am surprised how true the wheels run. They need either painting or a chemical treatment.
I also got the first coupler mounted on the other bogie wagon in the works:
Once painted I think you would not even know they were not the original Accucraft type mounting coupler boxes (I got a few from philipy, thanks mate!)
The added hook and safety chain is the Brandbright type.
That wagon looks good Tom, glad to help.
Actually, this thread inspired me to have a go a bogie wagon of my own a few weeks back. I did the bogies and then ......
it all kinda stalled!!
That looks great Tom, I like spoked wheels too..
Do you know where I can get single axle boxes from ?
Hi Rod,
Peter Binnie does a nice range in abs plastic that are easy on the pocket There is a link through the Summerlands chuffed website. He is very quick.
Thanks Derek..
