CDR Railcar No. 10
Re: CDR Railcar No. 10
Pendle Valley Models do a generic bicycle in white metal for about £2.50, or you can splash out for a 1950s style gentleman's Raleigh cycle from Trenarren Models for £19.95! Given you now have the ability to print items, I suppose you will be better to try and find a pattern online to produce your own period cycle!
Thanks. I think I'll resist the £20 job, but might be tempted by the £2.50 model, unless, as you say, I can find a decent 3d drawing.Lonsdaler wrote: ↑Fri Jun 05, 2020 12:06 pm Pendle Valley Models do a generic bicycle in white metal for about £2.50, or you can splash out for a 1950s style gentleman's Raleigh cycle from Trenarren Models for £19.95! Given you now have the ability to print items, I suppose you will be better to try and find a pattern online to produce your own period cycle!
Let me know if you do Rik. I've looked a couple of times in the past without finding anything worth having.
Catching up again on this superb build. Suits your line perfectly, Rik.
Following my comment yesterday, being unable to get outside in today's weather, I had another trawl around for bike files and came up with this one on Thingiverse:
www.thingiverse.com/thing:4050110.
By reducing the drawings to 40% on the slicer it comes out at about 95mm long which is again about right for a 16mm bike. An hour or so printing and 20mins assembly of the half a dozen component pieces got me this ( in works grey and still needing a clean up.): The files are labelled in Dutch ( I think) and that would explain the front carrier which would be unusual on a UK mans bike. It actually comes with the file to print a crate to sit on the front, but after a 60% size reduction it was too flimsy to print properly and I think I'll take the front carrier off, a couple seconds with a scalpel should deal with that.
The only other detail which is missing are the chain sprockets, and they would be easy enough to make up from a piece of styrene.
Thanks Philip
I must give it a try. Not sure my printer will produce such a crisp finish but certainly worth a try.
Rik,
Only after I printed and sprayed it and then posted, did I notice that it doesn't have a chain!!
I'm in the middle of trying to create that as an additional item, will let you know.
That looks an excellent representation of a period bicycle to me. As you say, a little work will give you the chainset.
