CDR Railcar No. 10
Re: CDR Railcar No. 10
That's looking wonderful Rik, well done!
And I take it back re the stripes, it doesn't need 'em at all, PLR Deep Crimson suits it perfectly!
Very much looking forward to seeing it on film in due course...
You've done a great job there Rik, a fantastic looking model. I'd be very proud of that.
Brian
That's a great idea, thanks. I do like the Walker railtruck. I'm thinking it would be unpowered - but there's part of me that would love to see it pottering around. Unless, of course, I make it so it can slot on to No. 10's motor block...... !!! Now where's my pencil?GTB wrote: ↑Tue May 26, 2020 2:30 pm I think you'd need something a lot more substantial than a Ford TT, or AA, truck chassis with a bus body to tow the CVR railcar around. The CVR Walker railtruck could do the job though, although it might look better if fitted with a van body, rather than the open tray of the original.
You must be psychic, Andrew.
I decided against the CDR colour scheme in favour of the PLR's. It fits my story of the directors travelling on the Clogher Valley Railway where No.10 originated and being so impressed with the CVR railcar they immediately ordered one just like it for the PLR.
Here she is now resplendent in full PLR passenger livery. As you can see, the paintwork around the bonnet has been tidied up as has the wiring on the cab
. The tractor and trailer units now sport the PLR's crest and handrails have been added for the convenience of the passengers - who are now seated inside (enjoying electric lighting)
. I followed the suggestion of adding strips across the roof to disguise the join - thanks, good idea.
. And there is now luggage on the roof - mostly 3D printed including the bike (but don't look too closely it's a bit too modern for 1932. Eventually I'll find a sit-up and beg model with a basket on the front!)
And, as requested, here she is in action
I am pleased to say she negotiated the trackwork on the PLR without issue, though I had to remove a packing case from the roof rack as it wouldn't fit under the bridge!
Rik love it, want one, how about you sell me that one, and build yourself a new one
You have really done the railcar justice. Lots of us have a soft spot for the CDR railcars. It fits in perfectly on your line.
What an absolute stunner, well done Rick, she is gorgeous and well worth the singed fingers!
Brilliant job, Rik. Looks and runs very well and fits your line beautifully.
Like most things, I see this as a learning experience. I'm not sure I've fully done the kit justice or yet quite perfected my soldering skills. The videos of master builders on YouTube make it look a lot easier than it turned out to be, particularly where access was tricky. Interestingly, the worst burn I got was picking up a blunt drill bit after trying to drill a hole..... !Peter Butler wrote: ↑Thu May 28, 2020 10:43 pm What an absolute stunner, well done Rick, she is gorgeous and well worth the singed fingers!
Thanks chaps. I've always fancied having a CDR Railcar and No. 10 looked the most appropriate. The later ones look too slick for the PLR - though some of the early 4 wheelers look very attractive ......invicta280 wrote: ↑Thu May 28, 2020 10:41 pm You have really done the railcar justice. Lots of us have a soft spot for the CDR railcars. It fits in perfectly on your line.
- Tropic Blunder
The railmotor looks good in service. The driver must be impressed with his new charge, as he is keeping it nice and clean.....
If the motor block you used under No. 10 is still available from the supplier, I'd be powering the railtruck. That way it can also be used on it's own for a bit of light shunting, or running light mixed trains on it's own.
From what I've read the motor unit of the railtruck was interchangeable with the motor unit of No. 10. It was sold without the motor to the CDJR and they are said to have used the cab to repair collision damage on No. 10. Looking at photos the only visible difference is a frame extension bolted on the back of the chassis to support the dropside body.
Like the railmotor, there is no visible cab door on either side, so presumably the driver had to clamber over the side of the truck portion to enter via the door in the back of the cab.........
Building the cab body work should be fairly easy in polystyrene, as you have the existing model to use as a pattern. The 'unit' as the CVR called it is a much simpler scratchbuilding proposition than a railmotor. Go for it!!
Lovely job Rik, and thanks for the film - the finished thing looks VERY at home on your line, particularly with the wagons trailing along behind. You'll have to watch it or the management will want to scrap all those expensive and extravagant carriages and steam locos and just order a couple more of these...
Pendle Valley Models do a generic bicycle in white metal for about £2.50, or you can splash out for a 1950s style gentleman's Raleigh cycle from Trenarren Models for £19.95! Given you now have the ability to print items, I suppose you will be better to try and find a pattern online to produce your own period cycle!
Thanks. I think I'll resist the £20 job, but might be tempted by the £2.50 model, unless, as you say, I can find a decent 3d drawing.Lonsdaler wrote: ↑Fri Jun 05, 2020 12:06 pm Pendle Valley Models do a generic bicycle in white metal for about £2.50, or you can splash out for a 1950s style gentleman's Raleigh cycle from Trenarren Models for £19.95! Given you now have the ability to print items, I suppose you will be better to try and find a pattern online to produce your own period cycle!
Let me know if you do Rik. I've looked a couple of times in the past without finding anything worth having.
Catching up again on this superb build. Suits your line perfectly, Rik.
Following my comment yesterday, being unable to get outside in today's weather, I had another trawl around for bike files and came up with this one on Thingiverse:
www.thingiverse.com/thing:4050110.
By reducing the drawings to 40% on the slicer it comes out at about 95mm long which is again about right for a 16mm bike. An hour or so printing and 20mins assembly of the half a dozen component pieces got me this ( in works grey and still needing a clean up.): The files are labelled in Dutch ( I think) and that would explain the front carrier which would be unusual on a UK mans bike. It actually comes with the file to print a crate to sit on the front, but after a 60% size reduction it was too flimsy to print properly and I think I'll take the front carrier off, a couple seconds with a scalpel should deal with that.
The only other detail which is missing are the chain sprockets, and they would be easy enough to make up from a piece of styrene.
