Tom's station building
Re: Tom's station building
Post by tom_tom_go » Sun Jan 20, 2019 9:52 am
I have used large domed rivets for door knobs, they can be chemically blackened!
Post by Andrew » Sun Jan 20, 2019 3:23 pm
The doorknob on this one's a pin pinched from the sewing drawer. There's a name for them I think, but I've forgotten what it it...
No, no plans to add lighting Rod, I wouldn't inflict my electrics on Tom! The roof will be removable though, so the inside could be detailed and illuminated at a later date.
Post by FWLR » Mon Jan 21, 2019 7:59 am
Thanks Andrew and Tom, both great ideas.... :thumbright:
invicta280
Post by invicta280 » Mon Jan 21, 2019 11:01 pm
Love that design.
Paulus
Post by Paulus » Tue Mar 12, 2019 6:33 pm
Very sharp looking station building. Any more progress on it since the last post? (Forgive me but I am just very curious to the end result :D )
Post by Andrew » Tue Mar 12, 2019 6:49 pm
Paulus wrote: ↑Tue Mar 12, 2019 6:33 pm Very sharp looking station building. Any more progress on it since the last post? (Forgive me but I am just very curious to the end result :D )
Not much progress, but I stuck the corrugated roof on last week... It just needs a little filling and sanding and it'll be ready for painting, but that'll be by spray can, so I'll need to wait for better weather...
Post by tom_tom_go » Tue Mar 12, 2019 7:05 pm
No rush Andrew :thumbup:
IanC
Post by IanC » Wed Mar 13, 2019 8:32 pm
Andrew wrote: ↑Tue Mar 12, 2019 6:49 pm
Spray cans at the ready here too, waiting for the better weather.
Post by FWLR » Sun Mar 24, 2019 8:27 am
If I know you Andrew, it will be painted with the same excellent skill you used on my wagons.
Post by Andrew » Wed Mar 27, 2019 11:23 am
Hi folks,
Having completed a few details and undertaken a little filling and sanding, yesterday evening it was finally dry and warm enough to start painting. It was a little windy in my favoured spraying position on the front path, and I only narrowly avoided spraying both my trousers and the car, but I managed to apply several coats of Plasticote primer:
Station building in primer.jpg (280.86 KiB) Viewed 5903 times
The window frames have been removed temporarily - the type I'm using are great like that, very convenient for painting. It did occur to me that a ticket office type window might look good in the office part of the building, but that wouldn't be in keeping with the original so I've resisted the temptation...
If the weather holds I'll try to start getting the top coats on over the next few days - a sort of beigey-cream I'm afraid, not lurid Hornby yellow!
Post by philipy » Wed Mar 27, 2019 11:32 am
That is really coming along well.
RobRossington
Post by RobRossington » Wed Mar 27, 2019 12:33 pm
Oh that’s lovely!
Post by tom_tom_go » Wed Mar 27, 2019 12:50 pm
It certainly looks like the Hornby R500 station halt I had as a kid now in 1:19 scale!
Post by ge_rik » Wed Mar 27, 2019 12:53 pm
Wunderbar!
I like the little details such as the bolts holding the corrugated sheets down on the roof!
Post by Andrew » Wed Mar 27, 2019 12:57 pm
ge_rik wrote: ↑Wed Mar 27, 2019 12:53 pm Wunderbar!
Those are made from... you've guessed it... nail art gems!
Post by Peter Butler » Wed Mar 27, 2019 11:00 pm
It looks to be most authentic, right down to the diagonal braces in the waiting area and the bench seating...... very good indeed!
Post by FWLR » Thu Mar 28, 2019 10:15 am
Just like the other members Andrew, I agree it's a brilliant job. Creamy-beige....nice..... :thumbright:
Post by FWLR » Thu Mar 28, 2019 10:25 am
Ps. I have done the same has Andrew with those little gems on my garage build....
Post by Andrew » Fri Mar 29, 2019 2:37 pm
Afternoon all!
The cream is on now, and here's how it's looking:
Staion in cream.jpg (267.24 KiB) Viewed 5733 times
I'm using Liquitex spray paint from an art shop, which definitely has pros and cons. The colour's exactly like the one on the can, the consistency's even, and the smell's not bad because it's water based - but because of that it takes ages to dry. Seems a little prone to running too, but I got away with it. Probably better for artists than modellers I think...
Progress is likely to slow for a while, but as a taster of what the finished thing should look like, here's a little test piece I did to see what green I'd use for the windows and doors and try our a weathering wash:
Station test piece.jpg (240.1 KiB) Viewed 5733 times
Cheers all,
Post by FWLR » Sat Mar 30, 2019 7:17 am
Very nice job Andrew. That paint does look good, even though you say it does tend to run. Did you need to rub it down or anything, or did you paint one side up first, then turn it when it dried?
