7/8ths fun
Re: 7/8ths fun
Totally agree with Peter and Phil, that front truss is a great piece of artistic design. Waiting to see what you do for the rest of it.
Re: 7/8ths fun
a trip to the local model shop and some more plastcard purchased the very kind bloke at the model shop had saved me some 00 gauge trusses that iv used. iv very nearly finished the water pump just some painting and some roofing sheets to finish .this has been very complicated to make the wheel took me ages but its getting there now.the model will work if I put a small motor on one part to get it to turn.
- Attachments
- 20180228_205730.jpg (434.74 KiB) Viewed 5116 times
- 20180228_205727.jpg (453.63 KiB) Viewed 5116 times
- 20180228_205723.jpg (479.97 KiB) Viewed 5116 times
- 20180228_205650.jpg (438.57 KiB) Viewed 5116 times
- 20180228_205643.jpg (407.71 KiB) Viewed 5116 times
- 20180228_205635.jpg (459.98 KiB) Viewed 5116 times
Re: 7/8ths fun
Very impressive Jim. You have quite an imagination to create that structure from a pile of random bits.
Re: 7/8ths fun
Wonderful work Jim, good to hear you have a helpful local dealer who takes a personal interest too.... good business strategy!
Re: 7/8ths fun
For a timber man, you have sure mastered the use of plastic Jim. It will be good to see it painted, different colours will make the machinery stand out from the building.
PS just noticed the rim of the flywheel, did you bend that, or find a suitable ring from somewhere?
Re: 7/8ths fun
Thank you all for your kind comments. The wheel was made from flat sheets of plasticard it did take me a while about 2 evenings
Re: 7/8ths fun
ok I think iv found some vehicles for the railway being 7/8ths there a bit hard to find but found some rc car shells that people use for banger/stockcar raceing .with the bloke who is 12th scale they look about right would like to know what everyone thinks
- Attachments
- 20180303_114526.jpg (392.64 KiB) Viewed 4730 times
- 20180304_084549.jpg (82.21 KiB) Viewed 4730 times
Re: 7/8ths fun
As you say Jim - looks about right. Some potential with that van moulding!
Re: 7/8ths fun
I'd be happy with that scale too Jim, quite a bit of work to do but worth the effort.
Re: 7/8ths fun
started painting the van tonight
- Attachments
- 20180304_204815.jpg (126.49 KiB) Viewed 4682 times
- 20180304_204340.jpg (122.34 KiB) Viewed 4682 times
- 20180304_204331.jpg (123.38 KiB) Viewed 4682 times
- 20180304_203715.jpg (134.17 KiB) Viewed 4682 times
Re: 7/8ths fun
looks quite shiny in the pics but its not sprayed it last night and started to weather it tonight
Re: 7/8ths fun
the water pump is now finished apart from the roof im still undecided what to use on the roof.
Re: 7/8ths fun
I may use some slate on the roof or find some tin sheet to put on that will rust
- Attachments
- 20180307_193920.jpg (157.43 KiB) Viewed 4642 times
- 20180307_193903.jpg (148.77 KiB) Viewed 4642 times
- 20180307_193853.jpg (144.49 KiB) Viewed 4642 times
- 20180307_193849.jpg (147.79 KiB) Viewed 4642 times
- 20180307_193842.jpg (148.75 KiB) Viewed 4642 times
Re: 7/8ths fun
now back to the minor van had some progress over the last few evenings its been sprayed .iv also started to weather the van and added a roof rack made from strips of wood burn on the gas hob to make them look old.
- Attachments
- 20180306_200953.jpg (149.1 KiB) Viewed 4642 times
- 20180306_211201.jpg (151.3 KiB) Viewed 4642 times
- 20180306_203143.jpg (159.9 KiB) Viewed 4642 times
- 20180306_211337.jpg (136.97 KiB) Viewed 4642 times
- 20180306_211749.jpg (145.51 KiB) Viewed 4642 times
Re: 7/8ths fun
one more evening painting the van and it should be finished. The ladder is made from plastcard and the wire was left over from lights I was fitting at work.i would like the van to have some worn sign whiting on the side but not to sure how to do this without painting it on myself.
- Attachments
- 20180306_213304.jpg (146.26 KiB) Viewed 4641 times
- 20180306_224409.jpg (140.74 KiB) Viewed 4641 times
- RylstonLight
Re: 7/8ths fun
Looking good, just the right amount of sheen without being glossy
Re: 7/8ths fun
You have made a good job of both of those projects Jim. The pump look great but I am particularly impressed with the work on the van.
Re: 7/8ths fun
Thank you for you comnents.I'm chuffed with the van painted a bit more tonight so it's just about finished just need the sign whiteing on the side.the company who make the shell make lots of different cars and vans so that's sorted all the cars etc I will need.being 7/8th there are is not a lot of off the shelf stuff to buy so having to cheat a bit by using 12th scale bits but I think it will work
