Am I looking at a real scene ? can't distinguish anymore.ge_rik wrote: ↑Sat Jun 02, 2018 6:08 pm More or less finished the landscaping and re-ballasting of the station area so here are a few pix of the sawmill and gantry crane in their natural setting.
A view from the end of the sawmill sidings.
The HGLW loco seems quite at home pottering around the sidings moving wagons under the gantry as needed.
View from the head of the sidings.
Moving in a bit closer. I need a few more stacks of sawn timber and a fair bit more clutter to finish off the scene.
The boilerhouse for the mill engine will eventually be placed in the bottom left of this pic.
Peckforton sawmill
Re: Peckforton sawmill
I can't seem to find any suitable words to express my admiration for this whole project, it's just sooooooo.....
On a more mundane note, what are you using for the ground surface finish in these shots? Again it looks so real and seems to be a perfect scale match, just like the real thing.
Thanks Phil
Basically:
I am constantly scanning the bagged sand and grit areas of local garden centres for 'interesting' concoctions - the RHA coarse sand is my latest discovery. I also sprinkle crushed coal in areas where it might be found - eg loco coaling areas, sidings where coal is unloaded. It's a bit like painting a canvas, except a bit grittier.1. I use concrete to bring the 'ground' up to sleeper height (or near rail height in the sidings)
2. Let that set (a week at least)
3. Dry-brush a mix of coarse sand, fine chicken grit, sifted potting grit, sifted soil and cement over the area
4. Water with a fine rose
5. Dribble SBR over everything (thanks to @Peter_Butler for that tip)
6. Leave to dry (a couple of days)
7. Daub watered-down cement dye over it all (thanks to @GregH for that idea) - I use black and brown separately and blend them as I go
There's a bit more information about my technique here - https://riksrailway.blogspot.com/2015/0 ... crete.html - though I've developed it a bit more since I wrote that.
- gregh
Looks really perfect in situ. It will generate a lot of traffic for the line.
I hope there's a big forest somewhere. Lucky it's the 1930s so no Greenies to complain about logging.
I like the way you let your sidings 'splay' out. Too many of mine (and others) are always in parallel. Yours give a much better look.
Greg from downunder.
Rik this is brilliant and far from anything I will ever achieve as I would of lost interest and moved onto something else. Using real wood for structures outside makes all difference.
I feel like an bottom saying this though but those plastic logs are the only negative for me as they look like they belong in a Playmobil scene.
Have you got a local wood you can go and grab some dead wood from the ground and cut up? You can then scatter the sawdust around the timber yard.
Hi Tomtom_tom_go wrote: ↑Sun Jun 03, 2018 4:40 pm I feel like an bottom saying this though but those plastic logs are the only negative for me as they look like they belong in a Playmobil scene.
I'd like to improve their appearance, sure. Their advantage is they are lightweight for wagon loads and weatherproof. I have tried various branches and twigs, but I find that if I leave them outside for a couple of months, the bark falls off and they end up looking,....... well, like twigs. I could probably use a couple on the loading platform for the saw carriage (underneath the gantry) as I take that inside when not in use, but I would like to have some permanent stacks of logs left outside.
If anyone knows of branches which have bark which is weatherproof, the please let me know. I'm sure I'm not the only one with this problem.
I've got a stack of logs made from offcuts of various dwarf conifers, and they seem to have kept their bark over the course of nearly 18 months.
"What the hell is that?"
"It's a bit big isn't it?"
That's useful to know. Annoyingly, I had a couple of rogue leylandii removed from the garden a month or so ago and they took all the brushwood away with them. Looks like I may have to prune some of my better behaved conifers.
Some of mine seem to excel at growing too big by themselves, to the stage where I am considering taking them out entirely, but it has produced quite a few scale logs whilst I try and keep them in check.
Rik…..how on earth are we going to do anything near your build…
Once again the sawmill looks fantastic…Can I have it please……
- gregh
Will you have to alter your computer program that allocates wagons now that you have 2 new industries at sawmill and watermill?
Good question, Greg and easily answered. Each wagon is assigned destinations and so I can adjust which wagons go to Peckforton or to the mill siding quite readily - just change a couple of numbers on each wagon 'card'. One day, I will add a siding to a sandpit and quarry (the area has had both in the past). Again, this will be an easy adjustment - just adding another location 'card' and then assign wagons to the new destination.
For those who have no idea what we're talking about - here's a link to info about my freight handling computer program - https://riksrailway.blogspot.com/2015/0 ... puter.html
I love that system you have Rik - adds a real sense of realism to the railway and its operation - I need to add more sidings to my line to get anywhere near - I do have a random element in my goods trains as to which wagon I remove from the consist at the other end of the line for the goods shed - as its that simple, I just use a dice but I would love to move to a more realistic scenario like you use
How about a vinegar lake too, then you can supply all of the local chippies? Just imagine the railway traffic generated by such an enterprise!
Is that to go on the wood chips from the sawmillPeter Butler wrote: ↑Fri Jun 08, 2018 7:29 pmHow about a vinegar lake too, then you can supply all of the local chippies? Just imagine the railway traffic generated by such an enterprise!
I'll get my coat.
You're not taking this seriously are you?????IanC wrote: ↑Fri Jun 08, 2018 9:28 pmIs that to go on the wood chips from the sawmillPeter Butler wrote: ↑Fri Jun 08, 2018 7:29 pmHow about a vinegar lake too, then you can supply all of the local chippies? Just imagine the railway traffic generated by such an enterprise!
I'll get my coat.
I am Rik, I still want your Sawmill……..
