Starting-up the diesel outline loco
- dewintondave
Here's my new baby. Chuffer not needed!
http://www.youtube.com/watch?v=XK6Q2RrAL8I
Best wishes,
Dave.
Best wishes,
Dave.
Best wishes,
Dave
Dave
- Johnnie2sheds
- DolwyddelanLightRail
- DaveWatkins
- dewintondave
It is a 1930's design by LBSC for an O gauge steam powered diesel outline loco. Perhaps diesels were starting to appear on the scene then. I scaled-up the design for 45 mm gauge, and increased the width a bit to match my LGB stock.
I've seen a picture of one other model made to the plans.
The loco has a large twin burner horizontal boiler up front. At the back in the cab there is a vertical single cylinder slide valve motor. It has a short stroke, and a larger bore. The motor drives the wheels by a worm gear. The steam is exhausted straight under the cab.
The flywheel is inaccessable, so there's a crank shaft extension front and rear which I plug the electric starter into. The motor has a slip eccentric and can run backwards too depending on which way the starter is going.
I am very pleased with the exhaust sound.
Best wishes,
Dave
Best wishes,
Dave
- Sir Clothem Cap
Sentinal built steam lorries and Locos that looked like diesels but were normallt Vertical boilers in the cabJohnnie2sheds:60825 wrote:Brilliant. Very Sentinelesque! :)
http://www.lner.info/locos/Y/y1y3.shtml
- DVT Dweller
They where built around the corner from our house, our house being built for the workers from Sentinel.Sir Clothem Cap:60860 wrote:Sentinal built steam lorries and Locos that looked like diesels but were normallt Vertical boilers in the cabJohnnie2sheds:60825 wrote:Brilliant. Very Sentinelesque! :)
Stunning looking loco and the crankshaft answers that bit that had confused me
