Setting up a MyLocoSound steam soundcard
After a request about how I set up MyLocoSound steam soundcards so they will go into 'coasting' mode when slowing down or coming to a halt, I've made a little video demonstrating the setting-up process. I hope others find it useful.
PS - This was set-up using a combined Deltang Rx65b receiver/ESC. Other ESCs might give different results.
Re: Setting up a MyLocoSound steam soundcard
Look out live steam...... your days are numbered!
Just seen this Rik and I must say what a brilliant video, although I have seen it 4 times today now, it is still a little bit confusing, but I am getting somewhere to understanding it because of your video.
Thank you.
Thank you.
P.S Rik,
What Deltang Tx and Rx do you recommend, I want to have separate TX and Rx for my Battery locos. I am thinking of getting some sound cards in the future, so would it be better with a Tx and Rx that can do them functions 1st or would it just be advisable to just get the TX. Or would the Micron systems be better, it is just a little bit of a mine field at the moment for me.
Sorry for going on with the questionβs...
In his post he states he is using a Deltang Rx65b.
Use can use whatever Deltang Tx you want depending on how many sound functions you want to trigger although the MyLocoSound unit does automate most of sounds by the looks of it.
No problem with asking questions - especially if they're ones I know the answer to.FWLR wrote: βWed Nov 22, 2017 12:50 pm P.S Rik,
As Tom says, I'd use the Rx65b combined receiver/ESC as it gives the greatest range of outputs and can handle a load of up to 3A. I've managed to squeeze my Rx65s into even the smallest locos.
The Tx20 gives the greatest number of buttons for triggering sound effects but I find that the Tx22 (which has fewer buttons) is quite sufficient for the effects I tend to use most (eg the whistle, safety valve and one other effect such as the guard's whistle or brake pump). The Tx22 has the advantage that it can control up to 12 locos independently.
Of course, I would say the RC Trains Txs are the best but I am probably heavily biased - to be fair the Micron controllers are likely to be just as good as they will be using the same circuity. I can't tell from their blurb though whether their cases have a battery compartment. Although the PP3 battery lasts ages, it is a bit of a fag if you have to unscrew the case to replace the battery.
It looks as if Phil at RC Trains is not taking orders for Txs at the moment and so, as far as I know, the only other sources of Tx22s are Micron or Yatton.
FWIW, I have a Tx22 /Rx65b/MyLocoSound setup, which works fine for steam sound plus loco whistle plus guards whistle
