Diesel Outline
- dewintondave
Diesel Outline
The exhaust note is the best feature!
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/du7DmgAdGk4?ve ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/du7DmgAdGk4?ve ... n_US&rel=0" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Best wishes,
Dave
Best wishes,
Dave
Best wishes,
Dave
Dave
- dewintondave
- Dr. Bond of the DVLR
- Retired Director
Thanks Dave :) If ever I'm able to get into live steam again that is pretty much the approach I would take with an oscillating cylinder in the cab and geared drive to the wheels.dewintondave:115437 wrote: I uploaded it for you Annie!
Best wishes,
Dave
Edit: Oops after a closer look I see that the steam engine in the cab of your clever wee loco isn't an oscillator at all. That will teach me to pay closer attention.
I snuck a look at your other video as well...... https://www.youtube.com/watch?v=lxeLsfhgzyM
The electric starter is intriguing. I suppose you need that because there's not a handy flywheel to flick with a finger to get things moving.
What has Reality done for you lately?
- dewintondave
- dewintondave
Yes, the way the loco worked out the flywheel became inaccessible.Annie:115450 wrote:The electric starter is intriguing. I suppose you need that because there's not a handy flywheel to flick with a finger to get things moving.
The cylinder has a big bore but a short stroke, and with cut-off makes it a reluctant starter. I start it with an Allen key too.
Initially the loco was started from the rear, but it was tricky. Then I extended the crank all the way to the front with the largest diameter I could for flywheel effect.
Best wishes,
Dave
Best wishes,
Dave
Dave
