Building a station building
Joe
Hi all as its a bit to cold to be doing any track laying at the moment (yes i am a bit of a wimp) i was wondering how you would suggest building a sm32 station building or waiting room as a project? i havent got masses of tools and drills etc but i have got the basics, just would like to know your different techniques to give me some ideas please.
cheers
Joe
cheers
Joe
It all depends on wether or not the building is going to live outside permanently or only in dry weather.
If it is going to be moved in after a running session then use anything you like. From cardboard to wood anything that can cut and stuck will do.
If you are looking to keep it out in all weathers then you have to use more resistant materials. Have a look through some of the other posts for more ideas.
I swear by foamboard (and sometimes at it), not the card foam sandwich but signwriters foam. It cuts easy and loves solvent weld glue. I use artificial slates for the roof to give a bit of weight. I have a post on the scenery thread called Eassie. I think it's a question of finding the material that you enjoy working with.
Post your progress!
Post your progress!
Joe
thanks all, ideally i would like to leave my buildings outside, i assume this stuff will do? http://www.ebay.co.uk/itm/1mm-3mm-5mm-M ... 46030ead32
here's my station I made you don't have to go too all the effort of putting on very small bricks though
http://gardenrails.myfreeforum.org/jack ... t6268.html
the jacksons minatures station is a nice little building to make or get one of peter jones books there very good for building ideas
here's another building easy to make with very little tools material's etc
http://gardenrails.myfreeforum.org/about7648.html
Joe
- planty
Here's a link to my attempts at a station building.
http://www.jasonplant.com/Pages/Railway ... ation.aspx
If I was doing it again I would use a more water resistant form of wood (think you can get mdf designed for bathrooms), although its withstood 3 winters the moisture has caused some warping of the base. Nothing major but could be avoided with a better choice of wood.
Joe
Working with foam board
Any advice on how to use foam board, what glue to use? etc
cheers
Joe
cheers
Joe
