Hi all
What are you thoughts on this. Say you took a standard boiler and a inline lubricator. The normal set up is the steam leaves the boiler through the regulator and travels through the lubricator and to the cylinders.
Now say you put the lubricator in a tender and there is flexible piping between the regulator and the lubricator and between the lubricator and the cylinders. Would the cylinders still receive sufficient lubrication despite the flexible piping?
Just wondering weather it would work or not...
What's your thoughts on this idea...
DVT Dweller
laurence703
kandnwlr
