Hi All
I am looking to build a battery powered diesel loco from a kit, I have got in mind a IP engineering Lucy or Fernor I like the look of these locos and the price, I would also think these could be built with RC, I want a loco that can pull around 10 binnie engineering hudson tipper wagons or around the same weight.
At this point I think I should also tell you that I am new to garden railway but not to building models from kits as I have been flying RC planes and helicopter for the past 25 plus years.
I know I could get a working chassis and put together my own body but as I have said I like the look of the above locos and for the money they look like good value.
Now to put all the above into a nut shell would these be a good way to go or is there anything better, and yes I would go with a chassis and put my own body on it if that is going to be the best option.
Thanks
Wayne
Battery Loco at a price
Vapouriser
Battery loco at a price
IP kits are very good. Well finished wood. The only thing I did with my 3 is to strengthen the motor mounts.Just in case. Ias you ve done r/c planes you ll have no trouble.
Vapouriser
Sorry. Dont want to mislead you. Mine are all wood. Others arent! Are you going to Peterborough tmrw?
Catweasel
Battery Loco
IP are good kits. You won't be disappointed with them. However,they can be improved at a reasonable cost. I would consider putting more batteries in them, a metal spur gear and 4 wheel drive. Delrin sprockets and chain aren't readily available at the moment,but Busted Bricks have a cost effective alternative with their belt drive system. Best thing is to get the kit, have a look at it and have fun. 2.4 Ghz radio systems are no problem.
