What is the best way to attach works and name plates to a Mamod since the body work gets hot from the pot boiler and/or fires.
Thanks!
Best method of attaching works/name plates on a hot Mamod...
- Superbiker_uk
I have had some good results with heavy duty double sided sticky foam pads. The ones that Sellotape make I have been found to be the best. The actual spec sheet for them says that they withstand temps from -40 °C to +80 °C. You used to be able to buy them in black but they only make them in white now. Not sure if you can find something similar in the US?
- Chris Cairns
