I hope someone can help!
Does anyone know where i can get a set of 3/16" bore gears?
Better still, a 3/16" bore gear that i can use with a drive(worm type) that is fitted to an LGB toytrain motor?
I'm scratch building a loco chassis, and i am using 3/16" axels and would like to make use on an old LGB motor i have.
Many thanks in advance!
Rob
3/16" Bore Gears
ianfolland
3/16" dia axles seem to be standard in 7mm scale modelling.
I've been using ABC gears for several years; http://www.abcgears.co.uk/ ;
Slaters also do gear boxes to suit a 3/16" dia axle; https://slatersplastikard.com/details/gearboxes.php
Otherwise you might find something here: http://www.gauge0guild.com/x-links.asp
Ian.
Ian.
