Also wondering about what price IP Janes go for?
Thinkig of saving up and see if any come up
Cheers in Advanced
Jack
Them pictures would be great. Thought making a loco from mamod bits would be easiest for a first steam build. Have a few ideas in my head.made-in-england wrote:Very possible. I know of one complete one made with significant re-engineering using all mamod bits with a few hombrew bits.. Belongs to steamyjim I think.
Another is all standard MSS apart from the cylinders wich are a binny steam motor.. the chassis has also been extended. I should be seeing the chap who made this one soon so can get some pictures if you like?
Will
ooooooooooooo, please no one bid, me want to winDolwyddelanLightRail wrote:There is a Mamod SL1 with 2 carridges of ebay at the mo currently for £30!
http://cgi.ebay.co.uk/Mamod-SL1-Steam-T ... 414effb6dc
Don't worry, i won't be at least!90733 wrote:ooooooooooooo, please no one bid, me want to winDolwyddelanLightRail wrote:There is a Mamod SL1 with 2 carridges of ebay at the mo currently for £30!
Well I'd prefer to tinker with mamod, something I wouldn't be scared of recking to much. Could repaint/try and line add bits and enjoy. I like that option (thanksEndless, Nameless wrote:A Jane would be cheaper than getting a Mamod to run to the same standards. I don't know how much experience with steam you have, mamods tend not to be the best running locos in the world anyway and unless your experienced, home built locos tend not to be as good as those made by experts either... Now, I know you have to start learning somewhere but I suspect that inexperienced builder + mamod components + scratchbuilding = dissapointment when it doesn't work very well.
If you want to tinker, get an old mamod and slowly rebuild it with bits and bobs from dream steam etc- that way the cost is spread out, you'll learn lots, and there's a good chance you'll get a decent running engine at the end of it. After that, you could look at making your own from mamod- esque components, and you'd have a good chance of getting it working.
If you want to run, save your pennies and get a SH Jane.
I'll do that then. I want to do all work on a mamod, not just cosmetic. Might make one look like a Jane, and try a hand at a repaint.Endless, Nameless wrote:Easy to make a Mamod look like a Jane, a simple matter of building a new spectacle plate! If you are happy to tinker and fiddle- swap the cylinders, fit a regulator and lubricator etc, get a Mamod. As you say, cheap enough not to be a worry.
Then, with the knowledge gained from that, build your own from bits and bobs![]()
If you are more interested in doing cosmetic mods, I'd get a Jane or pre- modified Mamod though as it'll run better that way.
