Self Powered Sybil
Self Powered Sybil
Post by Narrow Minded » Fri Jan 29, 2010 4:22 pm
After a strip down I managed to remove the ballast weight from Sybils boiler to make space for a battery pack.
There still wasn't enough clearance so I had to add the side "panels", blanking off the view under the boiler and above the frames................this in turn meant I had to narrow the LGB chassis to fit! :?
A DPDT switch on the rear buffer beam and she's now free running so the Battery Carrying Van (BCV) has been returned to normal service.
I thought now I'd also better fit lamp brackets fore and aft for light engine movements and while she was "in bits" I added regulator and sight glass detailing to the backhead.
PCLR
Post by PCLR » Fri Jan 29, 2010 5:12 pm
what type a power packs are you useing votls??
Post by Narrow Minded » Fri Jan 29, 2010 5:32 pm
At the moment 4xAA (6 volts) with just forward and reverse. It gives a nice steady speed with a light load.
The next step will be to fit 6xAA (9 volts) and a regulator.
I used an LGB chassis for my Locolines Hunslet but I replaced the motor with a 3 volt one, but wanted to leave this one "as is"
Post by 90733 » Fri Jan 29, 2010 7:58 pm
I like it :D :D :D :D
Nice job there, bet it looks good with a short train.
Post by Narrow Minded » Fri Jan 29, 2010 8:11 pm
Thanks very much! I'll hopefully get a pic tomorrow.
Post by Narrow Minded » Sun Jan 31, 2010 9:20 pm
Succesful running trials during a short break in the "Big Garden Birdwatch".
(I ran it when she wasn't looking! :D )
A nice steady pace but those converted LGB open wagons don't 'alf rattle!
mhlr
Post by mhlr » Sun Jan 31, 2010 10:50 pm
Corrrr it looks super Greg! Nice work!
