Edrig gas help
- 90733
Edrig gas help
Does any one know where i can get gas from to fit the gas thing from trckshack tht screws on?
- andysleigh
- andysleigh
- andysleigh
- andysleigh
Endless, Nameless
Just make sure you get butane, not a butane/ propane mix. You *can* use the mix, it will work, but propane expands a lot more than butane when heated, and an Edrig gas tank is right next to the boiler so heated it gets! Shouldn't be a problem, there's a massive margin of safety, but generally it's better not to risk it unless you know what you are doing, it says "butane only" on the gas tank for a reason!
- andysleigh
i'v always used mix, and so have many people i know, and its always been fineEndless, Nameless wrote:Just make sure you get butane, not a butane/ propane mix. You *can* use the mix, it will work, but propane expands a lot more than butane when heated, and an Edrig gas tank is right next to the boiler so heated it gets! Shouldn't be a problem, there's a massive margin of safety, but generally it's better not to risk it unless you know what you are doing, it says "butane only" on the gas tank for a reason!
Endless, Nameless
I knew you were going to argue with that.
You can do, it works. Doesn't mean you should. Apart from the very slim chance of your gas tank going boom (like I said, huge margin of safety) it'll make it harder to set the gas at a consistent level as the rapid and continued expansion of the mix will make it more erratic, although I suspect you'd only notice the difference running on a flat track at constant speed. In these temperatures the mix actually is advantageous as propane condenses at a lower temperature than butane, so no spluttery burner as liquid gas gets through.
Still says "butane only" on top of the gas tank and they aren't going to put that there for the fun of it, although I know it's mostly just covering their own backs. I just can't see the point when butane is easily availiable and at no price difference that I've noticed.
DolwyddelanLightRail
- 90733
PCLR
PCLR
SillyBilly
It only really matters if you are going to but boiling hots water around the gas tank, which I doubt you'll be doing on an Edrig.
That is a perfectly normal time to raise steam, Accucraft Garratts take about 15mins and but they have huge boilers. Don't worry about what PCLR said, there are plenty of people who run on B+P throughout the year, if it caused prolems with steam pipes then I'm sure there would be warnings.DolwyddelanLightRail wrote:i did slightly wonder why I got from cold to SV pressure in between 5-8 mins!
Endless, Nameless
Sorry- gas tank pressure not boiler pressure, should have made that clear.
It's fine at this time of year but slightly dubious when it's hot- different story on locos where the gas tank isn't by the boiler. Might not be sat in boiling water but it is sat by something that's full of boiling water, and made of a very good conductor of heat!
It's just like changing the safety valve from 60psi or whatever they pop at to 100psi. Perfectly safe to do, in theory- the boiler will take it- but it's reducing the factors of safety and not really ideal.
Like I said before, I can't see the point, unless the temperature is low enough (so, fair enough, like it is at the moment) for using pure butane to be a problem.
Users browsing this forum: No registered users and 44 guests
