Camera Vehicle
Nigel B
Camera Vehicle
Me again!
My camera wagon, for on train filming, is a fairly knackered chassis scavenged off a defunct brake van. The camera (iPhone) is attached to it using a tripod mount. I’m going to replace the wagon - any ideas or solutions for making it less bouncy?
Full line inspection following Storm Gerrit
https://youtu.be/dI3Ji9zL_c4
Cheers
Cheers
FeckHallBahn
Re: Camera Vehicle
Not sure why your video seems bouncy. The onboard videos I've taken don't seem to be quite so jittery but I didn't make any special arrangements - just attached the camera to whichever wagon was most appropriate. As far as I know, the cameras I used didn't have any image stabilisation features either and, AFAIK neither did the editing package - though I think my editor does have an image stabilisation facility if I wanted to use it.
I seem to recall, at some point in the past, a message popping up after I'd posted a video or two to YouTube informing me the video was jittery so did I want to be to corrected. I never used it because those particular videos were shot with the camera on a tripod, so no idea why YT thought they were jittery.
If you're using iMovie, then there is an image stabilisation tool built in, apparently: https://www.iskysoft.com/video-editing/ ... video.html
- Scrat
Re: Camera Vehicle
I use a cheap 2.4 GHz camera and receiver set built into a bogie passenger wagon.
The bogies compensate quite well.
The wagon is a former GDR production with a bakelite body so the antenna is hidden inside.
Powered by a 9V block battery it gives good service.
Any disturbancies created by switching points directly beside it (of course) result in the image flashing shortly.
Re: Camera Vehicle
I have more or less the same problem using SWMBO's iphone, but don't have a real answer. I have printed a holder to get the lens just about level with the flat wagon body but it tends to flex and tip the phone backwards and forwards as it goes along.
The holder is the black bit in this shot, with a lump of lead at the back to counterbalance it ( the grey box on top was to hold a small very old Vivitar video camera, and that works but the quality is too poor to even contemplate showing).
I think my Nikon D3300 might be OK but it is out of loading gauge, so a non-starter!
Nigel B
Re: Camera Vehicle
I wonder if a bit of soft (spongy foam) padding might absorb the vibrations.
Nigel B
Re: Camera Vehicle
It’s definitely worth a try, thanks.
However. The entire existing wagon fell to bits earlier so I’m going to build a new one - with suspension and a vibration damping tripod mount!
FeckHallBahn
Re: Camera Vehicle
I used that in my one and only bit of "driver's eye view" filming. Alas, the vehicle itself is not one of the most elegant ever to have graced these pages:Old Man Aaron wrote: Fri Jan 05, 2024 3:04 pm I wonder if a bit of soft (spongy foam) padding might absorb the vibrations.![]()
Refurbishing my old Mamod guards van is perpetually halfway down my "to do" list...
PS, the tin on the veranda is full of nuts and bolts to counterbalance the phone!
Nigel B
Re: Camera Vehicle
Following the earlier discussion, I decided to get a cheap 'spy' camera from Temu to see how it performed.
This video was shot about 30mins after it arrived in the post and was just the camera sitting loose on a flat bed wagon and being manually pushed along. So far I'm very impressed!
This is a link to what I bought:
https://www.temu.com/uk/1pc-mini-camera ... 28667.html
Nigel B
Re: Camera Vehicle
Hi - this looks spot on. What’s the power source; reviews on the product page aren’t particularly helpful!
FeckHallBahn
Re: Camera Vehicle
No, not much info on there and the instruction leaflet isn't much more help either, although it is written in better than average quality Chinglish!Nigel B wrote: Sat Jan 27, 2024 9:29 pm Hi - this looks spot on. What’s the power source; reviews on the product page aren’t particularly helpful!
The camera has an internal battery, but there is no info on size and/or running time. There is a usb socket and it says to use a 5v supply, as is usual. It had some charge when it arrived and then I just left it plugged into a 5v charger overnight.
It also has a microSD slot and I've used a spare 32GB card that I already had, but I'm not sure how big a one it will take. The switching between various functions is indicated by an internal blue LED and there is also a red LED that shows up sometimes but I haven't yet nailed down exactly what that indicates!
Re: Camera Vehicle
That's very impressive!
Maybe the technology exists already, but presumably it should now be possible to combine such a camera with phone-based RC so that you can drive, with a driver's eye-view, from the screen of a smartphone?
Re: Camera Vehicle
Andrew, Mine doesn't have wifi, only records to the on-board microSD card, but there are wifi models on Temu for not much more.
https://www.temu.com/uk/1pc-hd-1080p-mi ... cwjp5goog4.
It says it is viewable/controllable via its own app, so I guess if you put it in a loco and link it to your phone, you could then control the loco with the normal r/c whilst watching the drivers eye view on the phone?
Nigel B
Re: Camera Vehicle
I do that using my Apple watch as a remote control for my phone camera for my track inspections. Absolutely no need for it but it’s fun! Only problem with driving ‘live’ is lag and occasional watch screen freeze. Wouldn’t trust it with live steam
FeckHallBahn
- drewzero1
Re: Camera Vehicle
I noticed you looking at your watch viewfinder during one of your workshop videos. Seemed like a pretty neat trick when you're your own cameraman!Nigel B wrote: Mon Jan 29, 2024 2:33 pm I do that using my Apple watch as a remote control for my phone camera for my track inspections. Absolutely no need for it but it’s fun! Only problem with driving ‘live’ is lag and occasional watch screen freeze. Wouldn’t trust it with live steam
Re: Camera Vehicle
Ooh, that does look interesting... Magnetic too, it seems... Might need to investigate how far into the garden our wifi stretches - I think I remember sitting at the end working wirelessly during the pandemic...philipy wrote: Mon Jan 29, 2024 2:10 pm Andrew, Mine doesn't have wifi, only records to the on-board microSD card, but there are wifi models on Temu for not much more.
- dudeface
Re: Camera Vehicle
I think these things have their own wifi network, my drone does.Andrew wrote: Wed Jan 31, 2024 12:08 pm
Re: Camera Vehicle
Just a follow up on this.philipy wrote: Sat Jan 27, 2024 9:49 pmNo, not much info on there and the instruction leaflet isn't much more help either, although it is written in better than average quality Chinglish!Nigel B wrote: Sat Jan 27, 2024 9:29 pm Hi - this looks spot on. What’s the power source; reviews on the product page aren’t particularly helpful!I took a chance but decided that 8 quid wasn't a huge gamble if it turned out to be a rip off.
Tbh, it isn't a lot of use for what I wanted. The camera itself works fine, but it seems to be permanently set to look for IR.
When it goes dark at dusk ( or in a tunnel), the built in IR LED's switch on and it carries on recording as it is supposed to do.
The problem is that even in daylight in the open it registers the IR output of surrounding vegetation and the whole picture has a pinkish/purplish tint.
So, in this still taken from a video, the waiting room on the platform is green and some of the items a bit further away show in colours but you can see the IR effect generally particularly in shaded areas where the ambient light level is lower.
- drewzero1
Re: Camera Vehicle
At first glance I was blown away by the beauty of the cherry blossoms!
