Binnie Tub Body
sjrixon
Re: Binnie Tub Body
Post by sjrixon » Thu Apr 29, 2021 8:52 am
Doesn't look too bad. On my printer a little support would have helped, the print isn't clean underneath the curves.
20210429_081909 (1).jpg (506.57 KiB) Viewed 3244 times
I'll attack it with a file, sandpaper and primer later.
I'm also seeing if I can reliably print a chassis for it. It's on the printer at the moment!
Re: Binnie Tub Body
Post by FWLR » Thu Apr 29, 2021 9:53 am
That does look great on the chassis. I can see that the two parts that came off my print does make it look like they should be there. Good job I kept them.....
Hope the chassis is also a success, then we have a lot of printing to do for a nice long train of them... :thumbright:
Re: Binnie Tub Body
Post by FWLR » Thu Apr 29, 2021 9:59 am
By the way I have slowed the speed down to 50 and layer height 0.10. I find that the slower speed and the fine layer height gives a better print, lot slower but worth it in the end I feel.
sjrixon
Re: Binnie Tub Body
Post by sjrixon » Thu Apr 29, 2021 1:44 pm
The chassis came out ok, some tweaks as I printed the base in 3 sections. The axle is also a little short, as I made the chassis a little wide, so it wobbles a little. But I guess these did anyway ;)
Sat next to a standard Binnie Skip for comparison.
sjrixon
Re: Binnie Tub Body
Post by sjrixon » Thu Apr 29, 2021 7:50 pm
I think I'm happy with it. I've posted it, but I feel I need one more print to be 100% happy. You have been warned ;)
https://www.thingiverse.com/thing:4843877
Re: Binnie Tub Body
Post by FWLR » Fri Apr 30, 2021 9:41 am
Looks good that. Maybe I will wait though until you have done another print. Also can it be printed without the wheels. I like to use metal wheels, so no need to print them. I have downloaded the file but it will take over 5 hours to print, is that how long you print yours for... :thumbup:
sjrixon
Re: Binnie Tub Body
Post by sjrixon » Fri Apr 30, 2021 11:10 am
Agreed, about 4/5 hrs..
Just load it into tinker cad and delete my wheels..
It's on the printer, started about 8.30.. :)
sjrixon
Re: Binnie Tub Body
Post by sjrixon » Fri Apr 30, 2021 7:12 pm
Printed fine, 4.5hrs..
sjrixon
Re: Binnie Tub Body
Post by sjrixon » Fri May 07, 2021 2:25 pm
Printed and tested.. Wheels are printed too, they are fine.
