Morning all,
I am going to remove the cranks and conrod off my Bulldog loco. Was just wondering if the screws holding cranks in place need screw lock or are just tightened up as they are.
Thanks Alan.
Roundhouse cranks
Re: Roundhouse cranks
When you take them off you will see if any Loctite has been applied.
11thHour
Hi graff,
Belt & braces approach is always good, just make certain you use the right type of loctite!
Tim
Tim
Graff B.
Hi All,
Thanks for advice given. I checked the screws and found no trace of loctite, so,reassembled the cranks etc without loctite. They are nice and tight, but I will keep an eye on them in case they loosen.
Regards Alan.
Regards Alan.
