Easter Morning steam up of my LGB/Aster Frank S
Links to and discussion of garden railway video footage
artfull dodger
Post by artfull dodger » Sun Apr 01, 2018 5:50 pm
Nice sunny morning before the snow storm moves in this afternoon. So the lines new Frank S is out with the special after some mods to the exhaust set up The gunk tank was removed, the exhaust extended up near the top of the chimney with a home brew chuff pipe. Railway has settled a bit over the winter creating a bit of a grade just before the depot. Have to shim up that side once the ground firms up a bit. Anyways, Happy Easter!
https://youtu.be/syg0TnBVZ0w
https://youtu.be/Bz41HAU1mcw
Chairman
Chairman
Re: Easter Morning steam up of my LGB/Aster Frank S
Post by tom_tom_go » Sun Apr 01, 2018 5:52 pm
Slomo required on that racetrack!
artfull dodger
Post by artfull dodger » Sun Apr 01, 2018 6:23 pm
actually no danger of derailment with the LGB style flanges on Frank S. Once I relevel the table, I can run much slower. Kept stalling at the right front corner near where I was filming at. That is the crest of the little grade the line has from the winter settling of the table. I need to raise it up a bit and put a paver block under the leg on the far side right corner. The new larger loop that will be added this spring will also help, but will still be R1 curves.
