Wheel profile Lathe form tool
cncmodeller
Post by cncmodeller » Sat Dec 30, 2017 3:37 pm
Hi has anyone come across a pre-made Lathe form tool for turning wheel profiles? I presume ours would need to be coarse scale gauge 'O' I've looked online and in my catalogues but nothing comes up.
Thanks in advance.
John
Re: Wheel profile Lathe form tool
Post by GTB » Sun Dec 31, 2017 10:17 am
cncmodeller wrote: Sat Dec 30, 2017 3:37 pm Hi has anyone come across a pre-made Lathe form tool for turning wheel profiles? I presume ours would need to be coarse scale gauge 'O' I've looked online and in my catalogues but nothing comes up.
Coarse scale O would probably work, but the wheel profile shown on the 16mm association website for both 32 and 45 mm gauge matches the G1 'standard' profile.
Mark Wood lists a form tool for the G1MRA standard wheel profile on his website.
http://www.markwoodwheels.co.uk/wheels/formtools.htm
How big a lathe do you have? I've never used profile tools in garden scale, as my lathe struggles to turn the root radius without chatter, so no chance it would successfully turn a wheel in mild steel with a profile tool............ :roll:
Post by LNR » Sun Dec 31, 2017 1:36 pm
Graeme has raised a valid point. Having used one for 5" gauge you do need power and a good rigid lathe to use one successfully (mine is a 9" Hercus with a 1/2HP.) unless you do most of the work with a normal round nose tool and take a very very fine skim with the form tool.
Personally I find it just as quick to grind a round nose tool to match the root radius, set it up so that the left side matches the flange angle with the compound slide set to cone the tread.
PS I also write down cross and compound slide values to repeat same for all wheels.
cncmodeller
Post by cncmodeller » Sun Dec 31, 2017 2:58 pm
OK thanks guys, I hadn't thought of that I think. I'll get some wagon wheel rims of the correct diameter and cnc machine some centres and shrink the tyres on.
John
Post by Lonsdaler » Mon Jan 01, 2018 11:42 am
LNR wrote: Sun Dec 31, 2017 1:36 pm <snip> Personally I find it just as quick to grind a round nose tool to match the root radius, set it up so that the left side matches the flange angle with the compound slide set to cone the tread.<snip>
Do what now? :scratch:
It's amazing the difference in skills, experience and techniques that this hobby caters for, from bodgellers like myself to true model engineers. I am in awe :study:
cncmodeller
Post by cncmodeller » Mon Jan 01, 2018 9:10 pm
OK I'm answering my own question here but It may be useful for future reference:_
The tool 'Gauge 1 Standard' is the right one.
John
Post by LNR » Mon Jan 01, 2018 11:23 pm
Lonsdaler wrote: Mon Jan 01, 2018 11:42 am Do what now? :scratch:
I'm not sure, is that a question. If it is I don't understand.
Post by LNR » Mon Jan 01, 2018 11:42 pm
John (cnc modeller)
An apology, I guess if I had noted the CNC part of your name I might have realized that you have access to more sophisticated machinery than I have.
Interesting to note that in the form tool brochure he mentions that the Gauge one standard tool has the taper on the back to avoid a step etc. Important in wheels of the size generally associated with garden railways, and I believe the most important aspect of the whole profile to avoid picking point blades and check rails.
Post by Lonsdaler » Tue Jan 02, 2018 10:03 am
LNR wrote: Mon Jan 01, 2018 11:23 pm
Sorry Grant, I was trying to be 'with it'. http://onlineslangdictionary.com/meanin ... t-now%253f
I didn't understand the whole of the sentence you posted, and in my post I was trying to express admiration at the range of abilities within our great hobby, from the less skilled bodgeller like myself, to the true model engineers, like yourself.
I'll fetch my coat... :D
Post by LNR » Wed Jan 03, 2018 2:12 am
No worries Phil, you had me wondering. The online slang dictionary looks intriguing. Particularly "other terms relating to DO"
