Finishing the unfinished
- RylstonLight
Re: Finishing the unfinished
THE NEXT FINISH WAGON No15.
As I was preparing to restart the Lister I realised that a top-hinged door coal wagon (No15) still needed its door catches fashioning and fitting (and some tare weights added).
No15 with no door catches. Fashioned largely from reclaimed wooden fruit boxes which are an excellent source of distressed wood.
Marking and cutting out the catch from stock metal bar
One fabricated catch
Finished catch
Detail of the distressed effects you can get with using reclaimed wooden fruit boxes
And that another completed projected (I think).
Finished catch
- Soar Valley Light
And another row of awestruck faces reading this latest update Andy, I've no doubt. Your work is truly amazing.
- RylstonLight
The NEXT FINISH: The Lister (in progress still)
The IP engineering Lister was a stalled rebuild. I was trying to be too clever and put in a microprocessor control to make it more, well, controllable. The electrics worked but it proved a bridge too-far to fit it all into the limited spaces available. After much fiddling it was consigned to the back of the study-desk. To be honest I feel "KISS" is the winning principle here and decided to re-install something akin to the designed electrics.
The kit is some years old but I think is still listed on IP's website as current. The white-metal engine block casting is good for its era but the fan-cover has always looked to me as an oppressively blank face with the merest hint of casted grill.
Lister in uniform matt brown
Detail of fan cover with casting of grill just visible
Hopefully we can do better, a web-purchase of woven brass mesh from The Mesh Company cost a total of £3.39 for an A5 panel. They knocked 50p off for a Christmas bonus!
This was soldered to a turned brass bevel
And when offered over the original casting: it definitely shows promise.
Project status: progressing well
Very nice job on the fan cover.
I am looking at fitting rc to one of these. I managed to fit them in a standard simplex, but I think this one could be a real challenge.
- RylstonLight
I am intrigued, do tell more.
I am not milling away beneath the grill until I am happy the grill is convincing. It is clearly over-scale thickness. But I just gave it a quick dip in Carr's Metal Black for Brass to make it less obvious and offered it up again.
The final version will be finished in Lister Green with just the grill fading to black. Need to sleep on it.
That wagon is absolutely superb. True realism.
Totally agree with you there Grant.... hats off to the Master.
I think the engine is supposed to be a Lister LD. It may not have had a fan cover as it depended on what tinwork covered the flywheel. I think the mesh cover you have done is spot on. These engines and the locos they were fitted to were adapted and repaired over the years so I think that it is a case of anything goes.
This is how I crammed rc into a simplex.
https://gardenrails.org/forum/viewtopic ... ilit=Boaz
Wouldn’t you just know it, I had one of those 4 years ago, but give it to my brother for a project he was doing for his huge pond he has. I used it to drive a circular saw i had before my heart op...come to think of it, I haven’t seen it at brothers lately....
Number 15 is very nice indeed David, a truly beautiful piece of craftsmanship.
The amount of realism you guys achieve with making things look old is amazing. Sometimes i have to convince myself that i am looking at 19:1 not 1:1.
D.
D.
David T.
- Soar Valley Light
Amen to that David!
- RylstonLight
Happy New Year and thank you for all the kind comments but I have to suggest that my modelling is not altogether high fidelity, but more about "willing suspension of disbelief". I tend to be selective with what I model as "ultra-scale" as most can be much lower-fidelity.
The workshop was designed as a photographic stage, and so most of the background clutter and equipment is suggested by rough wooden shapes. As cameras have got better I am gradually improving the wooden ones to more scale models. Eg the lathe is still blocks of wood, but the drill press is slightly more detailed now. The photographs also help by maintaining maximum depth of field resulting in timed exposures, not a problem as nothing is moving. But shallow depth of field gives away a photograph of a model.
Below is an example of "willing suspension of disbelief". I find it easier to believe if free-lance models have plausible backstory that is suggested visually. The RLR in heritage times needed modern rolling stock and rather like the WHR looked abroad to import second hand equipment. The first modelled is No 63. I hope this is seen as a SAR-type metal-bodied wagon.
Once you know that it is a "Really Useful Box Company" plastic box stuck onto a basic plastic chasssis, with some added plasticard detailling; then it is harder to see the supposed 1:1 wagon.
Honestly not the high standards scale modellers are churning out all the time. However Peter Denny of Buckingham Branch Line (and a clockwork garden railway) fame used to claim that if everything the eye's sees is to the same standard it will tend to believe the model scene as real. I think it even more so with the camera lens if used judiously.
The modelling may no the the best but if you are willing to "disbelieve" and see into my world then that is a complement too
Bloomimng eck - great point well made - I was looking at the pic thinking you'd done a great LGB conversion and then after reading all your post and I look again, I can see the plastic box - great lesson!
Some very interesting points Andy.
Even although a railway item is generally the focul point of many pictures, my aim is to make them fit IN the scene rather than on it, if that makes sense. I'm sure you must get a lot of enjoyment setting up these wonderful scenes, I know I do. The camera certainly sees a lot the "objective" eye fails to notice.
Still brilliant work no matter how you look at them.
Lovely work. I use a longer version of there narrow box to hold my steamy bits'n'bobs in, and have often wondered if it could make a useful wagon. Now I know (in the right hands, anyway!)
- RylstonLight
Especially in the garden, the number of good shots I have ruined by not noticing a bright red wheelbarrow wheel in the mid-distance that draws the eye to it.
The Rylston Light is between incarnations, and I was planning the next version so that scenes "fall into" themselves to minimise real world parts of the garden intruding. It will have to be seen if it ever achieves the intent.
- RylstonLight
AND continuing the Lister project:
I managed to get several short runs in the (1:1) workshop that allowed me to "machine" out the void behind the new grill. Done with sequential drilling up to 10mm with electric hand drill, then use of handheld mini-drill (predates Dremel but same principle) with a ball mill.
As you can see pretty crude:
But when the grill is placed lightly up against the void the irregular edges are hidden:
And then next step will be spraying the raw metal, but not with today's weather. The rest of the afternoon was devoted to small repair jobs and my rolling programme of adding tare weight markings to rolling stock (interspersed with the odd nap!).
I have a nap or two every day...
- RylstonLight
Lister project continues:
This may get mired again as Big Jim has made me think again. RC size has greatly improved since the project stalled last time. Thanks Jim for link to Boaz project.
However there was some progress on painting until the wind got up again. It was finally finished as light was failing.
Tony, the Lister Renovation Project co-ordinator, stood back to admire the paint job after he'd lovingly applied the last brush-stroke. He insists that careful research showed that this was the nearest match to Lister green. The CME came across from the running shed and stood a full minute before gulping and walking back out to the twilight without a word. Old Tom muttered something about it "maybe be even more in yer face in 'daylight", with a definite impish smile. Hard to tell under the incandescent lights.
Still progress has been made.
