Llewellyn Loco Works #1
Re: Llewellyn Loco Works #1
Engineering can be learned but you are born to do it; very creative. I also like this hobby where family members enjoy to involve in the process.
What a talented and fastidious machinist you are. I wish I could see some of this happening in real life. It seems almost like magic. Oil holes in miniature connecting rods! The nerve!
- Hydrostatic Dazza
Thankyou for the compliments, I picked up the how to 0.50mm holes with PCB carbide drills at another forum http://modeleng.proboards.com/
Incredible attention to detail ...... I marvel at such precision. I think my tolerances are nearer to +-5mm!
- Hydrostatic Dazza
Working on the connecting rods. The B.W drawings has a small end pin at 3.2mm diameter going into a 2.50mm Con rod hole. I am not a fan of a steel pin running in the plain steel small end of the Con rod so I am intending to use 2.50mm pin (case hardened) and run it in a 0.40mm wall PB bush in the small end of the Con rod. The small end rod eye I made bigger to 5.20mm to give more room to accommodate the the bush. Much easier to replace a flogged out bush, if the need ever arises. The crank in the Con Rod to my mind very annoying and if there was to be a next time I would investigate the feasibility of redesigning the whole gig with a straight rod. I calculated I needed to make the Rod centres 0.14mm greater than the 80mm I have in my drawings, so the 80.14mm centers on the flat rod will be 80mm when the 2.40mm crank is inserted/pressed/bent. My dimensions may vary from the original drawings.
Made a pair of 5.20mm diameter filing buttons from some 1/4" silver steel and a 10 BA screw to hold them. Hardened the buttons with no tempering.
All set for the saw and file tonight.
Good batting by Roy last night.
- Hydrostatic Dazza
Thanks, but not really incredible
Cherry Hill and her work is incredible.
However these live on my head a lot of the time
$27.00 aud from Jaycar
while I bump or trip over every second obstacle
This is very true, Having had dealings with a number of the apprentices over the years, you can spot a natural. Skills can be learned, techniques can be honedEngineering can be learned but you are born to do it
but aptitude is a gift. I know I can teach anyone to weld (I taught the wife), but there is a big difference between some one who can weld and a natural welder.
- Hydrostatic Dazza
Silver steel filing buttons, hardened right out and a 10 BA screw
file file file, sand sand
each weighs in at 4.45 grams according to Solid Works.
What is next here ?
What is next here ?
- Hydrostatic Dazza
Now I know your secret.. You have a very well trained staff of dedicated workers to help you. For them all the small fiddly scale stuff is normal size and therefore easy to make..
- Hydrostatic Dazza
Yep, they are the brains and brawn of the whole "Potters Orchid Railway" gig
They have even been published
Me, I just do the marketing stuff
If I can get them to make the bikes then I could go fishing or hang out at some heritage railway and sniff stream oil and chew some coal while sipping tea
- Hydrostatic Dazza
Fiddly work.
Slide bars in place and the cross heads are moving, attached to piston rods.
Left hand side needed .02mm removed from the bar at the cylinder end and .20mm at the MB mount.
The dummy bolt heads that were loctited in fell out with the constant handling. I will clean and refit some replacements later.
The right hand cylinder needed .20mm shim at the MB mount.
I have concerns about the drag with the quad rings that I used on the piston.
Next is the bushes and pins and complete the con rod.
- Hydrostatic Dazza
I have introduced a Phosphor Bronze bush to the small end of the connecting rod. I was not keen on a 1.60mm wide steel con rod flogging about on a 2.50mm steel pin. A bush can be replaced, but correcting an oval hole in the small end of a con rod, "Errrrr yukkkkkk!" ( Errrrr yukkkkkk= Dazza technical term)
I also made it wider at 2.80mm to give more wearing surface. So while ABC Jazz radio played I started turning small and big end bushes. After some redrawing I got the centre line of the piston rod to the centre line of the con rod small end and reduced the crank in the con rod to 1.50mm which reduces the sideways forces and possible wear. Other wise the cylinder cover and gland takes up the lateral thrust as the cross head is not designed to. The vertical thrust is taken up by the slide bar and cross head. OK, the forces are small, but.......................
- Hydrostatic Dazza
Machining the cross head pins, will be case hardened later this arvo.
- Hydrostatic Dazza
For kicks and giggles, the 0.50mm carbide PCB drill did its work again. Oil holes in the con rod big end. I had missed pinning one crank to an axle so I have done that, 1.25mm silver steel pin and it is put aside for the Loctite to cure and then I can assemble the rods etc and check piston end clearance.
The first post on the rods was on 14th of January. This one is the 27th of January. So almost 2 weeks of work on 2 magnificent driverods.. Where do you get such patience?
- Hydrostatic Dazza
Thanks. I am self employed and I have to work to earn a crust of bread, so it is some evenings for an hour or two. I am not urging to have it done, a rush to have it running, but then being a bit let down by some of my perceived short comings. I am also terribly terribly slow. I measure three times, making a cut and repeat.........................make a cup of tea..............................make another cup of tea................. I am also working on the cab drawings now and soon the tender. Also how to fit the 5 servos in. All new stuff for me this RC gear. Last night I was checking and creating /printing off 2 D drawings for the anchor link and combination lever and associated pins. I also update and edit the 3D and 2D drawings after each part, so who ever might use these drawings in the days to come will curse me a little bit less than normal.
MAM and I are off soon this Sunday morning to collect rocks, to start a stock pile of terra forming materials for the Potters Orchid Railway.
I hear there is a big red rock over your way, that might look nice in your garden and I doubt they would miss a sack or two!Hydrostatic Dazza wrote: ↑Sat Jan 27, 2018 8:02 pmMAM and I are off soon this Sunday morning to collect rocks, to start a stock pile of terra forming materials for the Potters Orchid Railway. [/color][/b] [/color][/b]
