Busted Bricks - 7/8ths Simple Skip
Re: Busted Bricks - 7/8ths Simple Skip
Post by tom_tom_go » Thu Sep 28, 2017 4:27 pm
tom_tom_go wrote: Thu Sep 28, 2017 1:06 pm
I might have another go with the card but also just thought if I could create planked skip buckets. Did these ever exist?
I started with this (saved it from Milo just in time!)
And then ended up with my take on a planked skip:
I will add bolt detail and strapping but I think it works.
I squared the bottom of the skip sides off so to add a plank easier.
Post by Big Jim » Thu Sep 28, 2017 4:46 pm
I don't know about plank built skips, but I have seen some that were riveted from flat iron sheets. More mine dram perhaps, but it might be an idea.
Post by tom_tom_go » Thu Sep 28, 2017 5:26 pm
I could do that with the next one Jim using Plastikard, good idea.
Busted Bricks
Post by Busted Bricks » Thu Sep 28, 2017 5:33 pm
Post by tom_tom_go » Thu Sep 28, 2017 5:48 pm
Michael, I wish I had waited for that picture!
Post by bazzer42 » Thu Sep 28, 2017 9:00 pm
Prototype for everything if you know where to look. Clever thinking Tom, I like the look of that wood (and the source).
Post by tom_tom_go » Sun Oct 01, 2017 9:27 pm
What size nuts/bolts do you use for 7/8ths?
I would like to use scale nuts which are hard to find?
Post by Peter Butler » Sun Oct 01, 2017 10:02 pm
If you can't buy ready made nuts/bolts (heads) you could make your own by cutting thin sections of square or hex plastic rod which is probably available in a range of sizes.
Post by bazzer42 » Mon Oct 02, 2017 7:44 pm
I have some ba 8 - 12 size but use them sparingly as I'm too stingy to use them on every build. I much prefer my acrylic rivets at £2 a thousand :D
